4
8
longislandwrx
I agree with your detective work, that indeed looks like a LGT rack.
What fuel tank are you running? If stock, make sure you drill the hole in your firewall before installing that engine.
The rack worked out well. It turns out to be perfectly centered.
We are using Boyd tank, so no hole needed.
Larry
