I was planning on going the MR2 route. Mechie, can you specify which MR2 shifter would and would not work and why? Thanks
The Spyder shifters are plastic and a higher profile. The older ones are metal and very low profile.
Here are a few links to what you want...
MR2 Shifter 1
MR2 Shifter 2
I've bought my last 2-3 on eBay for under $50. There are deals out there if you are patient. The rust always cleans up with a scrub-brush and a fresh coat of paint. Easy to work on. You DO NOT need one of the short-shift kits. Those are likely for the Spyder shifters to make them feel more like the gen-1 shifter I'm talking about.
The stock Subaru lever has a bottom pivot with the linkage attached at the middle. Pushing forward pushes the linkage forward.
The FFR lever has a middle pivot and a bottom attached cable. Pushing forward (on the lever) pulls the cable backwards (opposite).
The early MR2 metal shifter has the same bottom pivot and center mounted cable.
Zero Decibel Motorsports
Check out my new website!
