0
0
101_0941.JPG101_0942.JPGStarted with side sales and rear fiberglass. The manual leaves out the 4" hole saw required to install the taillights also I highly recommend opening the direction light mounting holes with a 3/16 bit if you intend to use the #10 self-forming bolts. I also recommend that if you don't own a belt sander that you get one.
I need to find a lighter sway bar, the 20mm bar I have hits at full lock and pushes the bar into the spring
