Look at my post again and perhaps it will be clearer. I added another picture and more info. I don't even have upper mounting points now. They are gone. Upper control arm and ball joint will be inside the wheel. The lower ball joint assembly is stock, though it has been ground on quite a bit. Those two mounting bolts for the LBJ provide an opportunity for adding spacers or a custom steering arm.
I'm also working with Anze on inboard shocks/springs.
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
