Doowop
thanks Bob, I first found the vinyl expandable braided sleeves that is supposed to fit over the plugs, but the wrap around is even better. does it wrap well? when you bend the harness, does it have a tendency to want to open, or does it stay together pretty well?
Also, seems you seems to be very familiar with electrical stuff, have you ever used Amalgamating electrical tape? I was thinking it could be a good option for the wiring harness also.
The sleeve I used has the same melting point as the wire insulation. I would not use it on spark plug wires.
It wrapped very well and seems like it will stay well.
The OEM harness had some gooey tape in it. I used no electrical tape on any of my connections.
Every splice and terminal was done with 3M 3:1 adhesive lined heat shrink tubing.
http://www.waytekwire.com/datasheet/22013.pdf
I did try some laser printed wire tags that did not work out very well.
