STiPWRD
Bob, I like your wiper setup. Is it as simple as it looks? OEM wiper motor? How did you attach it? Thanks
It is a marine wiper system.
The motor has adjustable sweep from 40 to 110 degrees. Mine is set at 110 and left park.
The arm is adjustable length.
It will fit totally under the hood. I just left it stick out some to get better sweep.
This one is strong enough for a 28” blade. mine is a 20"
I made a nice bracket to mount it. But forgot to get a picture before I closed it up.
http://www.marinescreens.com/ongaro_...12v-60331.html
http://productimageserver.com/litera...de/41535QG.pdf
