Likes Likes:  2
Page 10 of 27 FirstFirst ... 8910111220 ... LastLast
Results 361 to 400 of 1079
Thread: MRG MotorSports 818S Build
  1. #361
    Looks like a clutch release arm boot.
    Hindsight
    Thanks for the suggestion. I found a bunch of possible boots.
    This one is out of a 57 chevy, It's got to be fast.
    here is a close up of the hole
  2. #362
    Visitor from Indy today
    We had a visit from our favorite part designer / supplier today.
    He fits in our car pretty well.
    If you didn't recognize him, This is Craig, also know as Mechie3.
  3. #363
    Tail light LED bulbs
    Just a word of warning about the tail light LED bulb.
    This is a three terminal LED bulb used for the reverse (white) and turn signal (yellow).
    The bulb works great.
    Be careful connecting it up. If you get the polarity backwards, it blows the circuit in the bulb.
    This is a stupid bulb design. Adding a 2 cent polarity protection diode is so simple.
    I could not believe it didn't have it.
  4. #364
    Exeter R.I
    Been there blew that lol. It is a stupid design.
  5. #365
    Exeter R.I
    Craig since when is your car that complete or have a blue frame. Lol
    Cool you guys met up.
  6. #366
    Good to know!
    How can you go wrong on the polarity? It's not obvious enough where the wires connect?
  7. #367
    Good to know!
    Not obvious to me.
  8. #368
    Mechie3's Avatar
    We were in town seeing a cornea specialist for the baby and decided to drop in on Bob. I like his seating arrangement. I'd probably move the wheel a little closer to me, but I tend to like a close up wheel. I liked having my legs stretched out and having my head under the rollbar.
    If the polarity isn't obvious to the electrical engineer I'm afraid I'm sunk.
  9. #369
    San Jose, CA
    I'm just starting on a schematic for my car and haven't made it to the taillights yet. Which pin is the ground?
    Pulled it out of the box tonight and figured it out. It is a standard bulb receptacle with a center common pin and the outside pins turning on the lights. I agree, really bad design not to have a diode.
    Side shift transmission video
    Mike and I had time to work on our side shift transmission modification.
    The reason for the side shifter is 2 fold.
    With the side shifter, the shaft sticking out the back and some of the housing can be removed.
    #1. For racers, allows for protective steel behind the trans and without the shaft it is less susceptible to damage from bump drafters.
    #2. Opens up the space for my rear radiator.
    Let me know if you have questions.
  11. #371
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    Wow that looks like a great solution!
    Tamra
    First autocross 3/29/15
  12. #372
    Quote Originally Posted by Tamra View Post
    Hi Tamra,
    as soon as I get my shorter cables, I'll video the backlash.
    FFR cables are 175" I'm going ~1/2 the length to 84" with 180* of less turns.
  13. #373
    Member Hendow's Avatar
    Sep 2014
    Not obvious to me.
    Oh so glad to hear it is not particularly obvious to a few more than just me!
    I like the idea of the two in one bulb, but I managed to create 'magic smoke' with both of my bulbs, and have been unable to source any replacements...
    Had to resort to standard wedge style filament bulb and a separate LED reverse light in the meantime.
  14. #374
    Quote Originally Posted by Hendow View Post
    Hi Hendow,
    here is a link for bulbs.
    http://www.amazon.com/IG-Tuning-60-S.../dp/B00C3MVK6G
  15. #375
    Sep 2014
    Hi Hendow,
    Thanks!!
  16. #376
    Clovis, Ca
    Nice work. I like it.
    I think the R guys would want a real bumper though. Even little bumpdraft would ruin/break/crack 3/4's of the rear bodywork. I have a fabbed bumper, and I'm still worried about getting tapped and how ex$pensive it will be.
    Thanks- Chad
  17. #377
    Clovis, Ca
    Is that trucklid going to support that wing? Or do you have a brace?
    Thanks- Chad
  18. #378
    Chad
    I agree with your comment on body damage. At least you can protect the transmission.
    My 818s has no plans for wheel to wheel racing. If I get bumped in the back, it's going to crunch my radiator.
    My next task is to seal up where the new shaft come out of the transmission.
  19. #379
    Sep 2014
    Hi Chad,
    No, the lid certainly won't support the wing once the car is underway. The wing is just sitting on the car, so I can get an idea of its suitability and placement. I plan to reinforce the underside of the lid by glassing in some alloy 'straps' or similar, then building a support frame off the lower chassis to take any downforce loads.
    My goal is to be able to open the trunklid with the wing attached, yet still have suitable structural strength underneath the lid, without having to cut too much of the beautiful carbon inlaid bodywork... one of a kind, so any cutting is done nervously and carefully!
    I'm really keen to get any secrets from your R spec brothers on their wing structure designs, as its an area that is not very well covered by FFR.
  20. #380
    Lokar Parking brake
    Installed my Lokar Parking brake today.
    Only went to the back right wheel.
    Thanks Wayne for the handle mounting Idea.
  21. #381
    Encinitas, CA
    Open diff? One wheel burn-out!
  22. #382
    Never thought about that, until now.
    Yes, I'm open diff.
  23. #383
    Michael was grinding a slot in a small steel bracket using a small angle grinder.
    He had the part clamp to the edge of a table. The grinder grabbed the bracket and shot it across the room.
    Hitting our powder coating stove.
  24. #384
    Mechie3's Avatar
    Bye bye! Hope he was wearing safety glasses.
  25. #385
    he was wearing safety glasses. The stove was 20 ft away.
  26. #386
    Orange, CA, USA
    Looks like a good excuse to build a bigger oven
  27. #387
    Building my ne shifter
    Disassembled my MR2 shifter. Going to rebuild it with a new baseplate and an ebay handle.
  28. #388
    Freeport, ME
    Going to keep the two cables above the shifter mount like the original MR2? Very interested, however it looks even shorter than the original MR2 unit
  29. #389
    The 2 shifters in the post above are the same length. MR2 shifter come in multiple lengths. The one you have is longer.
    I'm looking at moving my cables into the tunnel. not as simple as I hoped.
  30. #390
    Wow, very nice piece!! Came blue like that or you painted it blue like your frame?
  31. #391
    Leesburg, VA
    Bob, what issue did you run into? I also bought an MR2 shifter and was planning on installing it inside the tunnel where the base plate would be under the top tubes.
  32. #392
    Hi StiWRD,
    My goal is to get the cables down in the tunnel.
    I was looking at mounting a base plate on top the tunnel, then flip the bell crank so it points down.
    Then extend the shift arm down and connect cable outer jacket.
    In theory all would work, to implement it would be hooky.
    I think you and I are going to end up with the same thing. Last night I decided it wound be much simpler to just drop the shifter 2" into the tunnel to the tunnel, which would hide the cable and be pretty simple to implement.
    I should have this done by Wednesday, I will post pictures.
  33. #393
    Freeport, ME
    I'm making the tunnel taller, same effect. If you drop it under the tunnel the shifter is too low IMO, and my shifter is taller than yours
  34. #394
    Leesburg, VA
    Hi StiWRD,
    Awesome, I'll stay tuned. The handle you bought looks pretty nice (I assume you plan to leave that visible?). I was just going to use a boot so things don't have to be pretty underneath.
  35. #395
    That handle is to short and will be hidden if I drop the shifter into the tunnel.
  36. #396
    New Shifter design done
    Finished my new shifter design. My main goal was to get rid of the sloppy feel of the shifter caused by the backlash in the cables.
    Shorter cables with less turns did the trick. I feel it is as good as the stock Subaru shifter.
    I used parts from an MR2 shifter with 7' Teleflex xtreme cables. The mechanism is below the top of the tunnel, so a flat plate will cover it up. Picture and video below.
  37. #397
    Puyallup, WA
    That looks solid. Awesome work. The FFR shifter setup is definitely a downfall, especially with my 6speed trans. Ill definitely keep your design in mind if i decide to finally do something about it.
  38. #398
    Simplest design I've even seen! Looks so full race! I love it, but I'm gonna love my k-tuned shifter as well.
  39. #399
    Leesburg, VA
    Bob, that looks great, I may have to borrow. Can you take 1 or 2 more pics from the driver side?
  40. #400
    Freeport, ME
    Looks great Bob... Shifter is pretty low since you dropped it into the tunnel 2 inches. What did you use for a clevis on the fore and aft motion? I've been looking a how to best mate up the 1/4 -28 threaded cable with the huge stock MR2 attachment hole. I have my MR2 shifter rebuilt and mounted on a single 1/4 inch thick AL plate on top of the tunnel. I'll be making my tunnel about 3 inches taller than stock. Should be ready for a video in a couple days, the rear bell crank came out sweet and those cables are sooooooo much better! No slop at all.
    The cables are so good that I think that my upgraded billet FFR shifter (for sale BTW) with just longer Teleflex vs the junk cables would have solved many of the inherant shifting issues!
