Likes Likes:  2
Page 27 of 27 FirstFirst ... 17252627
Results 1,041 to 1,079 of 1079
Thread: MRG MotorSports 818S Build
  1. #1041
    Bowling Green, KY
    We have had a couple of Tesla's at a few events, we don't discriminate.
  2. #1042
    Do you know if they were able to keep charged with a normal track day time table?
    Did they plug into your 50amp RV (12kW) outlets? That is about a 15 HP charge rate.
  3. #1043
    Bowling Green, KY
    Bob i don't know if they were able to keep charged and run all the sessions, I will check with Matt. Yes one of them was in an RV Spot, anyway I will see if I can get more info.
  4. #1044
    This thread has been quiet due to weather and Family stuff.
    Merry Christmas to all.
    Bob & Mike
    summer 2016 NCM Motorsports Park
  5. #1045
    Bowling Green, KY
    Great shot Bob, Merry Christmas
    Looks like we will have some mid 60's weather next week and hope to sneak out and burn some laps.
    FYI I just got a Radium Fuel Collection box from Wayne, I believe it will help prevent fuel starvation I was having.
  6. #1046
    Been a while since I posted on this thread.
    Our first 818 has been put away for the winter. We remove our summer track tires and installed 205/55R16 on Stock Subaru rims. Picture below.
    Some of the plans for this spring are, side impact protection, add aero components and a power bump.
  7. #1047
    Hi Bob, and yes rubbing on it is a nice way to relax during lunch
    I have the APR GTC 300 that FF sells, AoA measured at the cent of the wing is 2* currently.
    We have a Mobil station on site with 87, 93, 98, 104 and 110 octane fuels, I had the the engine tuned to run 93.
    We going to see you at 10/10ths, MVP or our event next month?
    I didn't want to hijack tony's thread, so I move this to my thread.
    Planning on a track day but we haven't signed up for anything yet.
    Been busy on another project.
  8. #1048
    Hey Bob! Welcome back, you're still here, thought you left man, usually you post every day.
    Anyway, I was trying to find one of your build the other day and only found the other build, which I posted into.
    I wanted to know which build is the one you built like a boat? I think it's the blue.
    Then what did you do to prevent water from dripping down from the windshield and into the sides at the front of the doors? There is a small triangle right on the sides of the windshield and underneath is the start of the cockpit. My water drops there and I was trying to find a solution to prevent water from dropping on the sides inside the frame, and as much as possible preventing it from dropping over the battery too.
  9. #1049
    The blue frame car has a marine compatible electrical system. red frame isn't built yet.
    My car is a roadster, so I wasn't worried much about a few drops water in the cockpit.
    I left all the slots around the edge of the floor to let any water out. My car has been outside during full blown thunder storms.
    There is no issue with your 12v battery getting splashed.
  10. #1050
    Senior Member fastzrex's Avatar
    Oklahoma City
    Hi Tamra,
    The 2.0L pan holds 6qts, but the designed level is 5 qts with 1.5" of free space in the top.
    The STI pan holds 5qts, with the designed level is 5 qts with 0.5" of free space in the top.
    I will not be running the 2.0 pan low at any time. At idle the pan will be filled to 1/2" below the block. At max pressure the pan will be filled to 1.5" below the block. Witch is the design level for that pan. At steady state 2G's the pick up is covered. With the sloshing taking place, the accusmp will fill the intermittent times when the pick up is uncovered.
    If 4 quarts gets stuck in the outside head and only 1 quart in the pan, then I will suck air. But then the accusump will shove another 1.5 quarts into the oil galley and give me another 5-10 seconds of runtime.
    I would not run the STI pan over full. One extra quart and the oil would be 1/2" into the block. Add 1.5 quarts (total of 6.5) the oil would be into the crank.
    That is why I feel that the STI pan is not compatible with the Accusump.
    Bob, when you are talking about this particular 2.0 oil pan, do you mean an oil pan from a 02-05 WRX with a 2.0 engine? Will you/or you using/considering the KillerB 2.0 engine oil pickup or the standard pickup? Thanks!
    ~ Mark
    818C S/N 429ES: Start Date 1 September 2016
    2001 NB Miata LS3 V8 440 rwhp
    2004 Miata MazdaSpeed Factory Turbo
  11. #1051
    Quote Originally Posted by fastzrex View Post
    Fastzrex
    Here is a picture of the different pans.
    Top Left: Killer B Motorsport Oil Pan
    Top Right: OEM 2002-2005 EJ20 WRX Oil Pan Subaru number 11109AA053
    Bottom Right: OEM 06+ EJ25 Impreza WRX/STi (STi, Legacy GT & Forester XT) Subaru number 11109AA151
    Bottom Left: OEM 04-05 EJ25 Impreza STi (Legacy GT & Forester XT) Subaru number 11109AA131
    I have gone to a dry sump systems on our 818s. So no pick ups for me.
  12. #1052
    Some autocross pictures from this past weekend.
    Been busy on another project, but made it to an autocross this past weekend.
    Ran like a champ. Mike was 6th overall out of 64 cars there.
    Please ask any questions.
  13. #1053
    Bowling Green, KY
    Bob, great to see the car back out having some fun.
  14. #1054
    I love my job.
    I Love my job
    Most days I get to work on a very fast motorcycle.
    http://newatlas.com/lightning-ls218r...d-speed/50766/
    This week I'm working on 100,000 lbs (50 ton) coal mover.
    Thanks You POTUS
    If only I could find a way to get paid for working on the 818.
  15. #1055
    A couple of weeks ago:
    The fast electric motorcycle part of my paying job was out at Bonneville Salt Fats for speed week.
    We did not set any new records as the traction between the salt and our rear tire was less than aero drag.
    Kind of scary we the rear tire of a motorcycle breaks loose at over 200 mph.
    See article and datalog below.
    Green is speed,
    red is motor RPM direct chain to rear wheel(no transmission),
    purple is throttle (motor torque commend)
    . As you can see, each time Jim got over 200, the rear wheel would break loose and Jim would have to let off the throttle. Crazy ****.
    http://www.motorcycle.com/top10/top1...17-html.html/4
  16. #1056
    That's a shame Bob, but you will fix this and try again right?
    What's the fastest electric speed?
  17. #1057
    We have plenty of power, need to fix the salt.
    Our LS-218 is name after the Land Speed record it still holds 218 MPH.
  18. #1058
    Getting ready for this summer.
    Here are pictures of Mitch and i in the SINK HOLE. 818s VS 818r Both no paint, aero vs no aero, 3.5 vs 5" ride height. Street legal vs maybe. Dry Sump vs wet sump.
  19. #1059
    Mechie3's Avatar
    That pic has me thinking I should ditch the windshield on my S (since the glass cracked years ago anyways).
  20. #1060
    Might be tough to pass the wiper test without a windshield.
    Are you already street legal?
  21. #1061
    San Diego Ca 92106
    All you need is a pair of these.
    https://www.google.com/search?q=gogg...foBAXkQgjYIiAQ
  22. #1062
    Looolllll
  23. #1063
    This picture of my friend Tom O'Gorman's TCR car got me wondering if I need a bigger air inlet to my radiator.
    36391106_1757472180973461_805226520263000064_o.jpg 36460255_1760856223992622_6470481090279636992_o.jpg front.jpg
  24. #1064
    A bigger air inlet to your radiator would increase the air resistance of the car and reduce top speed. A better question to ask is if the cooling system you have is providing enough cooling to the engine. is your engine running hot?
  25. #1065
    Bowling Green, KY
    I would think not.
  26. #1066
    Problem with video's on the Forum.
    All of my video's I posted in the forum are not working.
    Does anybody know why?
    If I go to youtube, they work fine.
    Here is example of one not working.
    https://thefactoryfiveforum.com/show...l=1#post290085
  27. #1067
    San Diego Ca 92106
    The video worked on my Android phone
    By the way that coal mover is cool
  28. #1068
    Syracuse, NY
    Works on my PC?
    MK3.1 Roadster completed 2011
  29. #1069
    Sgt.Gator's Avatar
    Bend, Oregon
    Works on my PC, using the Chrome browser.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  30. #1070
    I got the video's to work if I run anything but "Microsoft Internet Explorer"
    Thanks for the feedback.
  31. #1071
    Today was a good day for our friend Tom O'Gorman. With co-driver Kenton Koch, Tom got his first win in TCR at Virginia International Raceway today. I'm sure some of my fellow auto crossers on here know Tom. Here is a couple of my favorite pictures.
    I guess you can shorten the corners if you only use 2 wheels.
  32. Likes Mitch Wright liked this post
  33. #1072
    I have a potential FFR customer coming by tomorrow to see an 818 in person. I at least had to clean it up. The never waxed or polished raw fiberglass and still shines pretty well.
    PS: sitting next to one of Mike's other toys.
    https://thefactoryfiveforum.com/atta...2&d=1565406378
  34. Likes Mitch Wright liked this post
  35. #1073
    Is that a 3 cylinder?
  36. #1074
    2006 Yamaha YXZ 1000R
    Yes, its a 3 cylinder, NA, 1000cc, 112hp, 5 speed manual. sequential shifter.
    winch, electric power steering, fox 3 way adjustable shocks, light bar.
    It's got the radiator in the rear bed to keep it from getting clogged with mud. We are in process of redesigning that.
  37. #1075
    Haaa, just like your 1st 818!
  38. #1076
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    Wow! That finish looks great, Bob.
    We've been slowly at work in our garage. Bought a 2006 WRX for a donor and finally pulled the engine 2 days ago. Maybe we'll get some time to actually post on the forum here...
  39. #1077
    Quote Originally Posted by fletch View Post
    please post every couple of day so we can watch your build progress.
  40. #1078
    Dec 2018
    We're more on the weekend-to-weekend schedule, but I hear you.
    All the best to you & Michael.
  41. #1079
    Option to remote reservoir
    This part should move your master cylinder out enough that you don't need remote reservoir
    https://www.outboundmotorsports.com/...K3QCB8rrflVxlA
