Page 20 of 20 FirstFirst ... 10181920
Results 761 to 779 of 779
Thread: 818Rasmus E Modified
  1. #761
    south-central CT
    Urg. Not what I want to see. I must avert my eyes.
    I have to pray that all my particles are beyond the bearings and all are headed towards the oil filter. Thanks, Debbie Downer...
  2. #762
    Senior Member Rasmus's Avatar
    Las Vegas, USA
    Sand to fit bearings, the latest in engine building technology.
  3. #763
    Las Vegas, USA
    This is how well mineral spirits and brass bristle tools clean aluminum. You know you're done went it starts to get that slight gold color. At that point the brushes have cleaned as much as they're going to clean.
  4. #764
    Las Vegas, USA
    And now for "Questionable Moments in Engine Assembly with Amateur Engine Builder Rasmus"
    Glued in main bearings! You can see the two little dabs of Loc-tite I placed in the stamped lettering on the back of that #1 bearing. I did it for all 10 halves. The areas of the bearings nearest the parting line have the largest diameter. If your eyes could detect it, the mains bearing are kinda egged shaped. Tighter nearest the thrust sections (e.i. the middle or 90 degree from the parting line). Fattest at the parting line. Before gluing them in I measured a ~0.0025" (+/- 0.0005") difference from the middle of a main bearing to 10 degrees from it's parting line. For example 2.3634" vs 2.3659". I used no loc-tite near the middle of the bearings. Only near 10 degrees from the parting line.
    I used so little that none of it squished out when I put the bearings in.
    Even after torquing the block together so the loc-tite would set up faster, none of it squeezed out.
  5. #765
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Very nice - so clean you could eat off it. You don't suppose that loctite will change bearing clearance in any way?
  6. #766
    Man that engine will be the most optimal in the World. I can't wait to see the results on the road and dyno.
    It is balanced and blueprinted right?
  7. #767
    Sep 2015
    Hamersville, Ohio
    Wrong use of loctite. It isn't an adhesive.
  8. #768
    Las Vegas, USA
    Loctite is an adhesive. In fact it's a thin, single-component adhesive that is methacrylate-based and relies on the electrochemical activity of a metal substrate to cause polymerization of the fluid. Loctite cures when exposed to electrochemically active metals, such as aluminium, and placed in an anaerobic environment. Source. Loctite works best in shear.
    I am only using it to keep my bearings in place so they don't fall out or rotate out of place during assembly, like last time. I'm in no way expecting this to keep the bearings in place while it's running. That's what the tangs are for.
  9. #769
    Sep 2015
    Hamersville, Ohio
    Rasmus,
    I cannot tell which Loctite grade you are using, but I have always used the 262 compound, and I can say without question that the adhesive qualities which you have extolled are the pressures induced from the anaerobic expansion of the product. When disassembling parts which have been bound together by Loctite, quite often it is possible to remove the remaining flake of Loctite with little more than your fingernail or light wire brushing. This isn't the same as a bond such as epoxy or similar. The product works well when applied to captivated parts, not so much for single-sided elements such as bearing shells. The expansion of Loctite pushes evenly on the entire surface, effectively locking the parts together, but on elements which aren't fully encircled by their companion part, it will not hold. For example, try bonding 2 flat plates together with Loctite. It doesn't have the bonding properties of glues or epoxies. As far as your application is concerned, I cannot argue against it, but I can say that neither I nor anyone else I know has experience with using this product for this application. If some errant product would end up in an oil passage, the results could be catastrophic, causing yet another lost engine. The Subaru engine design is tried and true, so I would not recommend departing from normal engine building techniques related to these engines. There are many people of all skill levels who read this forum for advice related to this engine, so I would recommend to these people to think long and hard about using Loctite for this application.
    Loctite is a very good product and has saved many users countless dollars when properly used, however everything has its place and I don't believe this is a good application for Loctite. In fact, I would question why the bearing shells were loose in their pockets to begin with.
  10. #770
    Las Vegas, USA
    Did some tests with chromate plated washers held in a vice over night with red loctite between just a small portion of their interior surface areas. It didn't hold. Now I know something I didn't before. Thanks.
  11. #771
    Las Vegas, USA
    Crankshaft installed. Pistons installed. Wrist pins installed. Wrist pin C-clips in and triple checked to make sure they're in. If I knew before what I know now I wouldn't have gone with+4mm over connecting rods. It's just crazy complicated for an amateur to put this together. If I could go back in time I would still go with a 75mm stroke crankshaft but keep pistons with their wrist pins at the OEM height instead of the +2mm mine are at. +4 mm con.rod causes you to have to go way off book to get the short block assembled. With +2mm you just assemble according to the FSM. So much easier.
    Tomorrow I hope to get RTV between the mating surfaces of the block halves, and torque the case bolts up for the final time; perhaps I'll have me a short-block.
  12. #772
    south-central CT
    Aww, let's see a smile! Knowing that you are about there and have it figured out, why not keep building them? I can hardly wait to hear mine scream.
    It's good to know that there is plenty of room to get sealant in there. Perhaps you will be replacing the wood with something like nails or bent wire when you go to applying sealant? How to insure that these spacers don't accidentally fall in and/or create a way to fish them out if they do? Am I overthinking this?
    Is that a Jeweler's screwdriver in your hand and about the coffee filters... What do you know about coffee filters that I don't?
  13. #773
    Las Vegas, USA
    Last time I just used two sockets to hold the block open to get the sealant in.
    Yes. It was going to be used to make sure the wristpin C-Clips were full seated. But there's just not enough room in there to get c-clip pliers, the jewelers driver, and both of my fat hands. Ended up using only the c-clip pliers to pinch and push. I only dropped, and had to fish out, one c-clip from inside the block this time 'round. Progress.
    I was watching a verbose youtuber that likes working on Mitsubishi stuff. He recommended them for use as lint-free cloths. So I decided to get them a try using the ones I already have at the house. They worked so well I went to a restaurant supply house, here in Vegas, and bought a 500 stack of the largest coffee filters they had. They're great. They don't leave lint or fibers on anything. Unless I snag it on a sharp edge or corner and rip it. They're super cheap. $12 for 500. They're white so I know when something needs more cleaning. Disposable, so I don't need to sneak a load of greasy, "lint-free", cloths into the washer. And an added benefit is I can use them to filter particulates out of some oils and solvents. For example, I filtered and reused the hydraulic oil for the 20-ton bottle jack I rebuilt last week.
  14. #774
    Mechie3's Avatar
    Some loctites can be used as adhesives. I've used loctite 648 to glue a hysteresis plate onto an aluminum backer for use in a DC motor mag brake application. I think what I'm trying to say is, Loctite is a brand, not a product, and they make many many different types of thread lockers and adhesives. Each has a different purpose and application.
    I once used a coffee filter to filter some 2 stroke oil that had gotten bugs and dirt into it. Slow going, but worked in a pinch when I realized the night before I was low on oil. Had no idea about the lint free properties though. That's pretty slick.
    Zero Decibel Motorsports
  15. #775
    They are also great for cleaning car windows.
    Congrats Rasmus. Epic engine build. Honeybadgers be praised. Your beard is shorter than I imagined.
  16. #776
    Senior Member Tamra's Avatar
    Apr 2014
    Shelton, CT
    So glad to see you back at it, Rasmus. We still have an E-Mod date in Lincoln sometime
    Tamra
    First autocross 3/29/15
  17. #777
    So cool to see you update frequently! Getting there man, getting there!
  18. #778
    Las Vegas, USA
    Yes. Yes we do. My driving skills are like steering-knuckles from Connecticut: rusty. But I can ****-talk like a pro.
    For the first time in my life, I built a shortblock. It's a 2.33 liter, 75mm stroke, 99.75 mm bore, with 134.5 mm c-to-c connecting rods. Called a Honeybadger by the Subaru tuning community.
    The temptation is to go crazy with the RTV when sealing the case halves together, but the pro's and experienced builders said and wrote to use just a light coat, yet insuring you get all the surfaces. Glad I went light. That how much squishes out when you torque it up. I even remembered to put the four o-rings in.
    Now what's an easy way to the the rear main seal in?
  19. #779
    south-central CT
    I believe I have been using a 3" PVC fitting.
    You could get fancy and put a cap on the end to hit against. I just bridged the end of the fitting with a piece of wood. Tap evenly. I believe they want you to put lube on the seal and again, my memory says that you put it in just flush.
    Glad to see the block together! Look purdy.
