Results 1 to 7 of 7
Thread: 2014 Rules Posted
    Challenge Series Director FFSpecRacer's Avatar
    2014 Rules Posted
    NASA has posted the 2014 Rules.
    2014 Rules
    Brian [email protected]
    Great Lakes & Midwest Region Series Director
    Knoxville, TN
    Well looks like the rear gears stay the same as 2013, option for 30 lb./hr injectors of any brand and associated MAF, and the new RR's of same 2013 size.
    #60
    Kirkland, WA
    Quote Originally Posted by Tuck60 View Post
    #60
    So we should not have to change MAF if we go to 30 lb injectors, I will most likely not go to 30 lbs unless the 24 lbs fail. I will go to the RRs even though they are little more expensive, as the RA-1 I would have to add $15 for shaving. So the RRs look like about $20 more per tire
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Yep..... RR is a better tire and does not need to be shaved. So cost increase is offset by the no shave.
    Knoxville, TN
    I am changing to RC engineering 30 lb. injectors along with a 30 lb. MAF.
    #60
    Be sure to note that the MAF is spec'd in rule 10.2. It is not "open" like the injectors.
    Knoxville, TN
    Got it...thanks Brian
