I thought they had more than 3 settings. Regardless, let me tell you these are stiff - REALLY stiff. I literally have to jump up and down on the frame to get the suspension to move - pushing on it does nothing. Even then, I'm lucky if I can get it to move an inch. Compare that to any production car, which moves quite a bit with just pushing. The suspension is designed and calibrated for excellent handling right out of the box.
I believe that there are 5 settings. They are intended to fit the application in the as shipped, softest position and then be adjusted stiffer as they wear with use. The red R shocks and the yellow S shocks are not the same construction or dampening
Dan
