0
0
I am kind of held up for go cart as my ECU is back at electromotive for repair. Everything else is done as far as running. I still need to work on an air intake and oil separator, but I need to do some body work first. I moved the dash back 3 inches because I could not reach the switches while strapped in. Now that I have it on the ground does anyone have ideas for jacking points? With the cf rockers and "R" ride height a floor jack simply wont fit.
