Thread: Easy Question on Alternator Mounting
    Just starting a Coyote build so just exploring the bigger questions of PS, pedal box, headers, clutch, etc. But in putting the Ford alternator on the Ford Coyote, what am i missing (sleeves?) on the pivot mount to the block? A 3/8" bolt pivots in the 1/2" sleeve on the block? Not impressed since both parts came from the same place. What have others done for this or did i just miss something?
    Have found some great help on the Coyote build site so far and a few familiar names from many years ago, but does not appear there are a lot of new posts on that site. Am i to assume that all of the helpful Coyote builders are on the road or using another of the forums.
    Thx.
    Senior Member Jester's Avatar
    I initially used a sleeve on the alternator bolt but I was not happy so I got a bolt with the proper diameter shoulder and proper threads. A simple fix that eliminates any of the unwanted movement.
    Good luck
    Senior Member DaleG's Avatar
    Mar 2013
    I got both from the same supplier, also. Came with a shouldered sleeve, nice tight fit.
    Ford racing says this is the proper bolt and reiterated that when the bolt is tightened the nut in the ear of the alternator pulls in to keep it centered. FR rep had even gone out to check an installation on a car to verify. While agreeing that the sliding nut assures a tight fit on the sleeve (end to end) when tightened, I feel he is looking at the wrong axis, and the bolt remains off center in the sleeve because of the loose fit. While he was firmly convinced, I will check with Ford locally, as it does not appear correct to me. For those who received a shoulder bolt from Ford or found a shouldered bolt on your own, can you send me a photo? (If you have it installed, don't go to the trouble of removing it.) Thx.
    Mar 2013
    Kind of hard to get at, but: (descriptions are in lower right of photos)
    Driver's side shouldered bolt.JPGPivot bolt with shouldered insert sleeve.JPG
    Mar 2013
    ny
    Where did you guys get a different bolt from? I also called ford racing and they said that on the production car the bolt fits the same way.
    Quote Originally Posted by RIPSNAKE View Post
    My build is complete so I don't have access to the bolt for photos. I measured the hole diameter and took the bolt supplied by FRPP to a local bolt shop and they had a similar bolt in stock with the proper shoulder diameter. I think it cost around $5.
    I checked my photos and unfortunately I did not take any with the alternator bolt
    15th Anniversary Edition
    Mk4 - 18 month build (4 hrs every Sat), received Aug 2011, titled & registered May 2013, final in paint Nov 2013 - Ferrari blue
    FRPP Crate Coyote 5.0, tko600, Moser 3 link, manual steering & 13" brakes, upgraded coil overs
    koolmat then dynamat then carpet in cockpit - very solid, no engine heat transfer to cockpit and no road noise
    I have no idea what size shoulder bolt it would take but McMaster-Carr has a large selection.
    http://www.mcmaster.com/#shoulder-screws/=t4sjvf
    Bill Lomenick
    Chotis Bill
