Frank, thinking about it more, I believe there is greater range of motion available at the shifter that isn't used with the Subaru gearbox. You probably have the range you need without modding the arm. Yours will simply swing a little more up top. If the throw is too much on top, and you aren't close to not having enough range of cable movement, you could mount it further up. I bet it works fine.
