Results 1 to 1 of 1
Thread: $23,900 2003 Factory Five Racing Challenge Car
Hybrid View
    Senior Member johngeorge's Avatar
    Nashua, NH
    Posting this for Dave Riha
    I am selling my 2003 Factory Five Challenge Car with extra set of wheels and two transmissions. I am the original builder, owner, racer. It has been a very competitive car. It has had its home in the Factory Five showroom and warehouse since it was built. It is in great condition, and has never been wrecked. It is very clean and very well built. The car meets the previous rules that do not include the power and brake upgrades. This car has an passenger seat. To make this vehicle physically street legal it would need the lighting wired up, a horn and a windshield added. The car is located in Wareham Massachusetts. Message me or post any question.
    Engine
    5.0L Ford V8
    1.7 Ratio Roller Rocker Arms
    Aluminum Under-drive pulleys
    Stamped Valve Covers
    Canton 7qt Front Sump Oil Pan with windage tray
    Vented aluminum oil overflow tank
    AFCO Aluminum Radiator
    Spal 18” Cooling Fan with on engine thermostat trigger
    JBA 1 5/8 Stainless exhaust headers
    Polyurethane Energy Suspension motor mounts
    Mobile One Synthetic Oil used
    Electrical
    Well organized, easy access simple wiring harness
    Ignition Coil mounted on engine
    Trunk mounted battery
    Cockpit mounted cut-off switch
    Headlights and Brake lights wired in
    Turn signals and license plate light mounted but not wired in
    Gauges-Auto Meter Ultra-lite Mechanical Tachometer, Fuel level, Oil Press, Temp
    Easy Read on dash clock
    Keyed ignition switch
    Wheel/Tires/Brakes/Suspension
    Enkei RPO2 5 Spoke Lightweight 20lb Wheels (17"X9" 5/114.3 w/35mm offset)
    Carbotech Panther XP Brake Pads
    Fox body 11” Front Rotors
    1994 Cobra 10.5” Rear Rotors and Calipers
    1994 Cobra master Cylinder
    Brake Bias valve in cockpit
    Castrol SRF Brake Fluid
    Front Brake Air Cooling Ducts
    3-Link Rear Solid Axle w/Panhard bar
    Koni Front shocks with 700lb Springs
    Bilstein Rear Shocks with 500lb Springs
    Toyo RA1’s
    Steering
    Fox body power steering rack
    Fox body steering pump with extended reservoir neck
    Redline Fluid
    Drivetrain/Chassis
    T5 Transmission with Steel Throw-out shaft
    Deist Safety Bell housing Blanket
    Hand shaped B&M Ripper Shifter arm for improved driver comfort
    Adjustable aluminum clutch quadrant
    Spec Clutch with Steel Flywheel
    Steel Driveshaft
    2.73:1 Ratio Ford 8.8 Axle with welded suspension brackets and axle tubes
    Black Powder Coated Chassis
    Driveshaft Loop Welded in
    Side intrusion plates
    Fuel
    Fuel Safe SM122-AFF Aluminum 22 gallon Fuel Cell
    Trunk Fill System
    Large Fuel Funnel fit to Chassis
    15 second fill for 5 Gallons
    Exterior/Interior
    Competition Windscreen
    Hood scoop painted black, not cut out for improved aero
    Driver accessible Fuel cut off switch
    In Car Lap Timer(needs trackside transmitter)
    Fire Bottle fire suppression system
    Hand held extinguisher accessible by driver
    Aluminum Kirkey Driver and Passenger Seats
    Simpson Seat Harness’s (out of date)
    Great visibility with convex side mirrors and curved center pedestal mirror.
    Easy paint touch up with solid red paint with decal add-ons
    Easy touch up flat black exhaust coating
    Custom Designed Heavy Duty Side Pipe mounts
    Padded steering wheel that is easy on hands for long races
    Additional Details
    Always cleaned thoroughly and checked for damage after every race
    1st Race was June of 2003 with normally top 3 race position finishes
    NASA race log book included
    Easily meets weight rules
    To make street legal the car would need the blinkers and license plate wired, a horn installed, and a windshield purchased and installed. The chassis has mounts for the windshield to mount up.
    Spare’s
    Enkei RPO 5 Spoke Lightweight 20lb Wheels with used Toyo RA1’s
    Rebuilt ready to use T5
    T5 that needs rebuilding
    Thank you,
    David Riha - dave(dot)[email protected]
    508-494-six0eight9
    http://johngeorgeracing.com
