0
0
Originally Posted by
David Hodgkins
This is the question I posted earlier, and referenced above:
Ken, quick question for you. Are you aware of the difference between standard and pin drive width? I only ask because it will impact your wheel choices. Are you going with pin drive wheels? 15" or 17"? If you are going with pin drive wheels, check out Vintage wheels, a new vendor on the forum.
Good luck with the rest of your build, and keep up the good work.
PS looks like our builds are very much alike. And you're a web guy. We actually have a lot in common!
I know enough about the difference between standard and pin drive width to get out my credit card, but whether that's been to good effect or not remains to be seen.
As for wheels, I have an FIA Pin Drive Wheel Set. I ordered them from Factory Five at the same time as my kit. I had them powder coated black, and I mounted them up with some 15-inch Avon CR6ZZ tires. They're sitting in my garage right now.
I'd be happy to hear feedback on these choices.
