Racebrewer
Anything similar for the rear?
longislandwrx
H6 upgrade. a 1.1" larger rotor and you can do it for about $120 if you get good deals. That with the right pads will make a SUBSTANTIAL difference.
What LongIsland wrote. The H6 upgrade. A Good "Poor Man's Big Rear Brake Kit".
That red brake adapter above is from the (H6 Legacy's? ) Subaru Catalog. It essentially spaces out the caliper.
Then you just run your stock caliper on the larger H6 rotor. Parking brake works and everything.
