0
0
Administrator
Originally Posted by
Santiago
Wayne, is a reservoir included as well? I didn't see it in the list of what's included but I thought you were originally offering it in the kit and you mentioned coolant volume, so I thought I'd ask.
Even if it is not included, any thoughts on what sort of performance level/demands would make one appealing in our application? For ex: typical use of an 818R vs 818S?
Best,
-j
It works so much better than the stock air to air even on a base 2.0 build. Add HP and that adds heat to the charge and it becomes even more important. I changed heat exchangers which deleted the need for a reservoir since the volume doubled and has a radiator cap.
