8
31
Bob_n_Cincy
What size tires and where did they not fit?
It's the +48mm offset that doesn't work. Rubs the rear links pretty bad. They're 17x8 wheels with 235/45 Z2's on them (for the WRX I daily drive)
C.Plavan
It will be fine as long as you place rubber around the holes- The metal will eventually rub through and give you a coolant leak. You can just get some fuel hose, cut it length wise and put it over the cut edges as a rubber gasket.
Oh good call, Chad. Thanks for that.
