Thanks Thanks:  8
Likes Likes:  31
Results 1 to 40 of 1012
Thread: Frank's 818R build
Hybrid View
    Feb 2014
    Asheville, NC
    After a ton of looking, I found a 2002 silver WRX sedan about 2.5 miles from my apartment complex, and maybe 15 from the garage I'm doing the build in (a friend's house).
    Motor:
    EJ257 block
    '10 STi nitride treated crankshaft
    Wiseco pistons
    Eagle rods
    Acl main and rod bearing
    ARP head studs
    Ej205 heads
    Ferrea valves
    Combustion chambers custom cnc'd for larger bore
    VF39 turbo
    Walbro fuel pump
    Deatschwerks 650cc injectors
    TGV deletes
    FMS 3" turbo inlet
    Turboxs fmic and recirculating bov
    12mm oil pump
    New OEM water pump
    Full 3in catless turbo back exhaust and catless up pipe.
    Transmission:
    Exedy stage 1 clutch
    Gruppe-S flywheel
    Bent 1-2 selector fork :'(
    Supposidly JDM micro polished gearset. We shall see when the transmission gets rebuilt
    Body is a 2002 silver WRX sedan in pretty good shape. Has full interior (which is mostly ricer-blue...... ) and gauges. It's also really close which is ideal for moving it. Guy has tons of pictures and receipts for all the work. Motor ran nicely and everything looks good so far. I'm hoping it's actually the deal I think it is at $4,800.
    My small collection of WRXs
