8
31
Hindsight
For used transmissions, check
www.car-part.com. Its an online wrecker database. I have used it to find obscure parts very successfully.
STiPWRD
Give Andrewtech a call, they specialize in subaru transmissions and usually have some used ones on hand. (240) 683-1000
Thanks for the ideas, guys. I called my buddy Sam at Andrewtech and am getting an 06 WRX trans! That'll work for now.
Engine is installed, front hubs are on the car as well. The steering rack needs to be re-dyed at ball joint. Those threads have seen better days. Hopefully salvageable. Next up are things like mounting the seat, fuel lines/filter, and coolant hoses.
Also, picking this beast up Friday! 5 speed, 4.9L straight 6, cap, and almost no rust(was a Southern truck before 2012). Drove it last night and put a deposit on it right away. Should do just fine as a tow-rig
