Thanks Thanks:  8
Likes Likes:  31
Page 24 of 26 FirstFirst ... 142223242526 LastLast
Results 921 to 960 of 1012
Thread: Frank's 818R build
  1. #921
    Garage is warm in the winter, and (more importantly, in NC) cool in the summer.
    Say that again? NC? Where has gone CO?
  2. #922
    Feb 2014
    Asheville, NC
    I moved from NY to NC with New Belgium ~2.5 years ago. I spend some time out at our first plant (CO) but I'm mostly down South (and more importantly, that's where my garage/house are)
    Frank - Build thread
  3. #923
    Oh! Ok I thought you fully moved to CO back then.
    Well as long as you continue painting on your wall every single track you track onto, that is really awesome! I love the idea! Those are trophies, even when you get disqualified from some of those races due to, I dunno, lack of fuel, say... loollll
  4. #924
    Feb 2014
    Asheville, NC
    about 90% done with the re-wiring. Trimmed a lot of stuff, made things the right length (less there and back), separated them into distinct harnesses a bit better, and color coded the sections. Check out how clean my rear light harness is! Hoping to shove the harness into the car this weekend
  5. Likes Zach34, Mitch Wright liked this post
  6. #925
    You trimmed to save weight?
    You did that lime green wire sleeve? Looks nice!
  7. #926
    Feb 2014
    Asheville, NC
    I actually mostly trimmed it while waiting for my transmission to be fixed (it's back now), but it was kind of a mess and not color coded at all. It's a lot prettier now. This wrap SUCKS to apply but it's quite nice.
    filled this box up twice with scrap wire.
    This is what it looks like laid out. Not great but a lot nicer than before. Bunch less wires, nicer connectors, some color coding, and a lot less messy
  8. Likes aquillen, Mitch Wright liked this post
  9. #927
    That's nice, man!
    A couple hours more and your awesome race car will look like mine (but running well).
  10. Likes Pearldrummer7 liked this post
  11. #928
    Feb 2014
    Asheville, NC
    So, I put the harness in the car. It feels much more organized and protected than before! Still not as clean as an iWire harness, but I've had fun and the price is certainly right.
    I'm thinking I'm gonna put the engine compartment fuse box and the interior fuse box in the center tunnel, and build a little hatch to access them. Thinking I'll put it here and then cut out the red section of the tunnel cover to make it accessible (hinged or clipped in, perhaps?)
  12. #929
    Yes make sure the fuse box is accessible!! Don't do like me... loll
  13. #930
    Feb 2014
    Asheville, NC
    I had it very inaccessible too at first. It totally sucked lol I don't know what I was thinking. Here's some before and after of the trans tunnel cover
    I'll take any tips anyone can give on making it prettier in there. Functional enough for me right now, but looks pretty meh
    I had all my switches on this little plate I made. I'm nervous to cut into the dash because I don't have the highest confidence making a hole for each of these and I worry I'll be outta luck if I ever change switches. Any dashboard thoughts?
  14. Likes Frank818 liked this post
  15. #931
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    You could play around with using thin aluminum sheet (super thin stuff - hardware store flashing is cheap but a little hard to work without crinkling it) as a dash cover plate. Then if holes need to be changed later you just make a new aluminum plate. Aluminum can be painted or powder coated although it can be fussy about "stick" sometimes. Or if you are into wood grain, some veneer or wood look vinyl over aluminum or direct to the dash, again something that lets you re-do if ever needed. Done carefully even a sheet of thin lexan / polycarbonate would work.
    So possible materials to make a face plate, most of which are Home Depot, Menards, etc:
    aluminum sheet such as .03 thick
    aluminum flashing
    plastic sheet - lexan / polycarbonate
    formica / equivalent laminate
    Vinyl / Naugahyde with/without a stiffener backing like al flashing / even thin cardboard
    wood grain - veneer products
    wood grain look - automotive stick on vinyls
    hobby craft type plywood panels - some are incredibly thin - hobby stores, hobby lobby, Menards (not sure they go thin enough)
    For bonding to the dash consider some screws or rivets, otherwise glue it on. That adhesive I used in my build thread to do the vinyl to the dash holds like crazy.
  16. Thanks turbomacncheese thanked for this post
  17. #932
    Feb 2014
    Asheville, NC
    Quote Originally Posted by aquillen View Post
    aluminum flashing
    Art-- I just looked through your thread extensively. It's extremely impressive what you've done to the interior. I think I'm going to take a page (or a chapter) out of your book. Appreciate the suggestions man
  18. #933
    Feb 2014
    Asheville, NC
    So, while the engine is out, I figured I would (re) replace my leaking cam seal and try to figure out why that happened. I took off the timing belt following the FSM, and when I did the tensioner sprung and spun the driver's side cams. Not a lot, but the valve can interfere with both the piston and each other. So I've ordered a leakdown tester (happy to receive any advice on giving it a test). A few friends said it's unlikely that they're damaged but I am worried about it. Anyone with experience on that front?
    Good excuse to clean the engine up a bit.
  19. #934
    Apr 2014
    Hey frank which radiator shroud did you go with?
  20. #935
    Sgt.Gator's Avatar
    Bend, Oregon
    It's extremely unlikely the valves are damaged if you had the crank in the correct position when you took the belt off. If you think about it, what causes the cams to spin a little? It's because they are slightly under tension of the valve springs. When you take the belt off and they turn they are just being turned by the valve spring pressure, and that pressure is closing the valves, not opening them further. So they are moving away from interference, not towards it. And they only spin enough to bring all the valves to closed so the tension is gone.
    Of course it's completely different if you lose a timing belt while the engine is running.
    A leak down test is good anyways for lots of reasons, so go ahead and do it, but if you have a leakdown issue it's probably not because the valves are damaged from taking the belt off.
    Owner: Colonel Red Racing
    818R ICSCC SPM
  21. Thanks AZPete thanked for this post
  22. #936
    Feb 2014
    Asheville, NC
    I was not thinking about which way the valves were springing, which is of course away from the piston. I just got nervous with the bolded warning in the FSM. I'm still gonna do a leakdown test (hopefully tonight) and see how it is, but the more I read and think about it, the less likely it seems that it's damaged while not running. It'll be telling!
    I appreciate the reassurance, Gator!
  23. #937
    Feb 2014
    Asheville, NC
    Quote Originally Posted by Newkitguy View Post
    Hey! I have no radiator shroud; just running with the mounts from Mechie3/Zero Decibel Motorsports and the stock radiator. Were you thinking of Canadian Frank with his (now blue) new-front-end 818? Can't find exactly where the shroud is but it's around or after here
    https://thefactoryfiveforum.com/show...-Thread/page36
    Fun fact, I have his old spare nose from when he upgraded (years ago)
  24. #938
    Apr 2014
    Perhaps....my mistake
  25. #939
    Feb 2014
    Asheville, NC
    Leakdown tested the engine this weekend with a friend. I had concerns about being TDC and holding timing steady after a few little slip ups, so we did it both with the timing system in and without (valve covers off and valves closed, just held the crank) and the results [which were almost exactly the same]:
    11%-----9%
    15%----15%
    (with the bottom text being the front of the engine). Not bad; fairly consistent? Little high; heard it through the crankcase breathers and oil, but again not a huge cause for concern for me. Thinking this means I will not pull the heads. What is, however, a cause for concern:
    Why is there so much Fuji Bond (RTV, whatever) covering the engine? Gonna take a deeper look, clean everything up, replace all gaskets nearby.
    Got this sweet cam holder. It makes working on timing a lot less frustrating.
  26. #940
    No way!!!! That red carpet is exactly the same my parents had until 2 months ago! Did you steal it from them? hahahahahahah
    That's a nice cam holder tool, you got 2 sides to work on and I guess it's a lot easier when the engine is out. Happy I got a VR6 for those 2 reasons, though.
    Are those the corrugated hoses you got from me?
  27. #941
    Feb 2014
    Asheville, NC
    haha they're actually from my SO's parents. Her father collects foreign rugs and gave us a ton of them. I had to pinky promise to not damage the few in the shop
    Yes they are the hoses from you; I love these things. Jealous of VR6 timing; seems easier than the Subie
  28. #942
    Feb 2014
    Asheville, NC
    I checked valve clearances while in here. Pretty close, but all a little loose. Intake range from 0.23mm to 0.25mm (spec is 0.20 +- 0.02), and exhaust is anywhere from 0.30 to 0.38(spec is 0.25 +- 0.02). I have the old shim over bucket style, which isn't fantastic. But since loose is conservative vs tight, I'll take a little power loss and leave well enough alone, don't y'all agree?
  29. #943
    south-central CT
    I think I'd leave it. I don't know if more heat makes clearances close, but certainly the wear of seat and valve close up the gap. Mods can effect it.
    ON my race engine, with beehive springs and 272 high lift cams, I once set the valves on the tight side and after a year and something I burnt two valves (started seeing compression loss).
  30. #944
    I'm really happy my body parts and tubing are in good use on your car, keep things going, man.
    Speaking of cam timing, https://thefactoryfiveforum.com/show...l=1#post388687
    It's a race car, no power loss allowed (no out of gas as well!), make it as powerful as possible and rebuild the engine after every track day. loolll
    Sorry I can't seriously help on this one.
  31. #945
    Feb 2014
    Asheville, NC
    Figured, I've heard these horror stories enough times. Trying not to see the valves again for a few years.
    I started to torque the caps back to spec and it felt WAY too difficult, and the cam shafts couldn't even rotate freely at that torque. I started looking around and found a thread talking about how 14.5 ft*lbs is a misprint and is only for the rear camshalt bolts (8mm). The cap 6mm ones are 7 ft*lbs, which feels MUCH more correct. I got to thinking about it, dug out some old RTV from that mess on the engine, and found where this got the previous owner too. Explains the gobs of RTV there. Careful if you're torquing a bolt according to the FSM, there's mistakes in it!!
  32. #946
    Clovis, Ca
    Make sure to change those sub strap mount points- They are very unsafe there. They need to be under the seat. Your Family Jewels with thank you if you have an accident.
    Thanks- Chad
  33. #947
    Feb 2014
    Asheville, NC
    added to the to-do list. Thanks for the suggestion, Chad!
    Made a new switch panel, because my old one was embarrassingly bad.
    The second I sat down Vern joined me. Doesn't like being in the race car but loves to be around it.
  34. Thanks biknman thanked for this post
    Likes Scargo liked this post
  35. #948
    Just make sure there won't be any cat fur flying around and sticking on those cams!
  36. #949
    Feb 2014
    Asheville, NC
    a few tries later, I got the right covers in, and set out to destroy, er, repair the stuck bolts in the block. There are so many of them! Not like they're easy to tap.
    it ain't super pretty, but it's buttoned up! feels nice
  37. Likes DSR-3 liked this post
  38. #950
    Feb 2014
    Asheville, NC
    engine is in! wiring, plumbing, clutch tonight or tomorrow, then tranny!
  39. #951
    You can save yourself some potential challenges if you remove that metal shield plate from the bottom of the engine before you try to slide the tranny in. It is much easier to take it on and off than it is to line up the tranny with it in place.
  40. #952
    Feb 2014
    Asheville, NC
    Quote Originally Posted by sgarrett View Post
    I did that, and it was much easier. Also, I didn't realize how gross that little plate was until I took it off and started cleaning....ew.
    Got a bunch of stuff in! Lot left to do (torque things, intercooler pluming, fluids, plugging tons of stuff in) but it's getting closer!
  41. Likes Mitch Wright, Stephen115 liked this post
  42. #953
    Feb 2014
    Asheville, NC
    So, while I have been quarantined (working from home), I've had plenty of time to be buttoning up the race car....and scope creeping! wooooo.
    Was just going to tighten up the throttle, and I broke this little plastic piece when I took it out, so I made a new one from a bolt I had that had a pretty close looking countersink angle:
    Just popped a small hole in that, and got some new cable and a new end (from Summit racing, it's a Dorman Cable End 3337, fits perfectly in the throttle!)
    Since I used a 7x7 1/16th" cable I ended up needing to drill out the cable end a bit (5/64th, just a 1/64 bigger). I also popped the same size hole in the little end I "fabricated"
    Also got rid of 2 washers per bolt that hold in the throttle bracket but shortening the bolts a touch, using the tried and true die-and-hacksaw method:
  43. #954
    Senior Member AZPete's Avatar
    Good thinking!
  44. #955
    Feb 2014
    Asheville, NC
    Put the seat in to recruit my lovely SO to help me bleed brakes and clutch. Getting really close to a test-start. Sounds silly since it ran last time I started it (1.5 years ago or so) but I'm still nervous about all the changes working smoothly.
    Sat in that seat for WAY too long. I'm so excited!
  45. Likes Kurk818, Mitch Wright liked this post
  46. #956
    aquillen's Avatar
    NW Indiana
    Sitting in the seat now and then, but not being able to drive = excellent motivator.
  47. #957
    YES!!! I totally agree.
  48. #958
    Feb 2014
    Asheville, NC
    Got a used GTC-250 with the Gurney flaps for a few hundred bucks (thank you the internet!). My friend owns a fab shop and has a huge plasma table, so sometime we're gonna crack some beers and start designing a better rear bumper (as I lost the removable one in the move down south) and wing support. Been looking at a few of your mounts and love what you have going on.
    Needs fluids, battery hooked up (on the charger now), shifter adjustment, and a once over to make sure everything is tight, and then we'll go for a start/drive!
    ....but that got interrupted by moving our entire ~750 sq ft garage into the shop so we can paint the walls. Yes, I have too many motorcycles.
    Also, we got a kitten! Had a foster that we thought was forever, and the original owner came back for it. New kitten loves the shop, so expect shop cat pics soon.
  49. #959
    Syracuse, NY
    Oh man, that's a smoking deal on that wing. I have the same one, but paid full price
    MK3.1 Roadster completed 2011
  50. #960
    Your garage is really cool, is that the one with wall drawings of every race tracks you raced on?
    And do you have more pix of that black and red bike?
