Starter Solenoid (not the Solenoid on the Starter) questions?
Background Info: Complete Build, Carbureted, Supplied FFR wiring harness, Breeze supplied Starter Solenoid frame mount type and Mini-Starter kit.
1) I assume the Starter Solenoid large terminals are interchangeable as long as the wires going to each terminal are correct. Clearly the small terminal is for the Lt Blue ignition switch wire. Is that correct?
2) If the Starter Solenoid is not attached to the frame, it must be grounded to the frame via one of the bolts used to attach the Solenoid case. What size/gauge wire should be used to ground it? I wouldn’t think it would need to be a 4-gauge battery type ground or should it?
3) Is there a case to cover the Solenoid? The exposed terminals make me nervous.
Mk IV, Complete Kit, FFR 7304
