Results 1 to 17 of 17
Thread: FFR Roadster 7486 Is Complete!
    On March 1, 2014, at 2 pm I put in the floor mats and my roadster was finished! This was something I took on as a retirement project. I have always loved cars but really did not know much about how they worked, and what better way to find out than actually building one! I've always liked to "build" and do things myself, but this was a big challenge. I chose not to do my own engine - more than I wanted to chew off - but was able to be at the shop when the top half of the engine was built, so I at least got a pretty good understanding of what goes where and why. And with dropping it into the car and all the connections to make it run, I met my needs for that part. I had attended the build school to convince myself I could do this, and was happy to find out I would be able to get it done. I began the build by picking the kit up on April 1, 2011. And then the fun began. I would be lying if I did not admit I was ready to quit on many occasions, but time on the forum, a couple of beers and a fitful night of sleep usually got me ready for the next day and resolution to my problems. There are some things I wish I could do over - cracked windshield, poorly placed drills, faulty measuring tools (can't be my fault!), boy I thought that would work?!? - but I am happy with the outcome. I did end up with a couple of spider web cracks in my paint from transporting on the body buck (if you transport make sure you cushion between the buck and the body!!!). Depending on the light and where you are looking from they are either invisible or frustratingly obvious, but I resisted the urge to swallow anti-freeze, and my painter and I agreed I would assemble the car, we would give it some running time and then come back and take care of any flaws when the weather is a bit nicer (below zero when I got up this morning). Like others, there were some frustrations with some of the parts and instructions, but I could not have done this if not for everything FFR has done to make it possible for someone with limited car knowledge to build such a great machine. Overall, a very worthwhile and fulfilling project. Oh, and an awesome car as a side benefit!
    Here is a link to some photos: http://www5.snapfish.com/snapfish/th...NAME=snapfish/
    If you are not a Snapfish member and don't want to join, here is another, easier link to photos: http://gallery.roadster.mightypirate...ed-car-photos/
    Light was not really good for the pictures today, but you get the basic idea.
    Details of the car:
    Complete Kit FFR7486 - Paint Chevy Corvette ('73) Silver Mist code 914 with Chevy Corvette ('66) Nassau Blue code 976
    3 Link rear suspension, 3.31 gears
    Vintage gauge set
    Kirkey Hi Back Aluminum Seats
    Adjustable Seat Tracks Driver and Passenger
    Seat Heaters
    FFMetal Battery Box and Fan Shroud
    Replicaparts Dash Steering Hole Trim, Seat Belt Trim, Underdash Filler Panel and Weatherstripping kit
    Heater/Defroster (did not connect defrost)
    Windshield Wipers
    Stereo with four speaker system
    Custom vinyl on dash, shifter and e-brake boots, Herb's Door Panels and trunk lid access cover
    Dash extension below dash with heater vents, stereo, seat heater controls and 12V adapter plug
    Expanded driver footbox
    Halibrand 17x9 front and 17x10.5 rear wheels
    Nitto NT555-Extreme Tires - 255-40 front and 315-35 rear
    Engine - Ford 302/347 Stroker/425 HP with Powerjection III EFI
    Eagle Cast Steel Stroker Crankshaft
    Eagle I-Beam Connecting Rods
    Keith Black Pistons
    Custom Ground Hydraulic Roller Hi Performance Street Camshaft
    Roller Lifters
    1.6 Ratio True Aluminum Roller rockers
    Aluminum Performance Intake Manifold
    Powerjection III 750 CFM Throttle Body Assembly
    62 1b/hr port style injectors
    MSD Pro-billet distributor, MSD 6AL ignition control, MSD Blaster II Coil
    March Performance Pulley Kit
    Tremec TKO600 Transmission
    Ford Racing Bellhousing, Clutch fork, Clutch kit and Throwout bearing
    I did also keep a build page online to keep track of what I did - and re-did and shoulda did and wish I didn't - here is the link:
    http://www.roadster.mightypirates.com/
    Thanks to everyone on the forum for your questions (I had a lot of the same) and answers and help with my build. Now, I just have to wait for warm weather, pray for luck with PA DMV/DOT, and then I can enjoy some driving!
    Last edited by Broadwaydan; 03-05-2014 at 09:30 AM. Reason: Updated links for photos
    Dan
    Mark IV. Pick up April 1, 2011. Complete Kit, 3 link, 3.31 rear, 347 Stroker with Powerjection III EFI, Tremec TKO600. Build completed March 1, 2014. See build info at : http://www.roadster.mightypirates.com/
    Fresno, CA
    Congratulations on the accomplishment! A very nice looking addition to the growing number of completed roadsters around the world.
    Doug
    Senior Member Scott Zackowski's Avatar
    Oak Ridge, North Carolina
    Ditto on the congratulations. Very nicely done. You should be proud.
    Senior Member DaleG's Avatar
    Mar 2013
    Great! You should be proud of that one.
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Great job. Now in joy the ride
    Great work Dan! Enjoy it
    2bking's Avatar
    Garland, Texas
    I enjoyed your build site. Just wish I could see the photos without joining SnapFish.
    King
    Congratulations! Really like your build site.
    Carl
    NY
    Congrats!
    Senior Member JimiD's Avatar
    Congrats Dan!
    Delivered 11/12/11
    2014 small fall cruise http://youtu.be/fwk0TXXZGEU
    First Start: http://youtu.be/547P6SHGixI
    Go Kart 2/12: http://www.youtube.com/watch?v=CQSUL-6q15k
    King and others - my bad on Snapfish. I guess I have been a member so long I forgot they want you to join to see photos. I updated the main post with a new link to the photos - easier to get to. Also have it here:
    Everyone, thanks for the comments.
    Dan
    Master Builder
    Long Island, NY
    Like you choice of color , dont think have ever seen that before !!!
    Kenny
    Feb 2014
    congratulations, nice job
    Fort Lauderdale Fl.
    Very nice work, congratulations.
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Looks great. Love the color!
    Web/build site is a great resource.
    You all must be very proud of your hard work. Congratulations!
    Senior Member christenfreedman's Avatar
    Lookin Good!
    Senior Member JL1958's Avatar
    Atlanta
    Great looking car.
