.Doing the final radiator tweaks before I take it to the TIG welder. Lower outlet had to be moved over and angled up, but other than that its an off the shelf radiator. I will end up with the grille shell and radiator as separate units so either can be removed individually. I may even be able to swap the Konis out without pulling the radiator. Fan goes in front as a pusher.
IMG_20170304_155554_990 (640x361).jpgIMG_20170305_114743_943 (640x361).jpgIMG_20170304_155519_919 (640x361).jpgIMG_20170305_114820_100 (640x361).jpg
Nice to have the overflow pointing the right way. How much wider is the Plymouth grille?
Dale
