Heat Shield Fabrication - Complete
I dedicated the day on finishing the fabrication of heat shields, so I can start riveting panels together.
Here's the passenger side foot box before the alteration. Notice the holes cut on the front and inside panels. Those are for the A/C lines and heater hoses.
The fabricated heat shields are done and mounted to the foot box. The reason I installed the urethane engine block and headers was to take measurements and make sure that the shields would have clearance from the exhaust once mounted to the panels.
Finished the driver side by fabricating the last heat shield, which shows on the photo installed on the inside panel.
I can finally concentrate on powder-coating and permanently attaching panels to the chassis, with a few exceptions... There are still a few mods coming regarding chassis panels.
Carlos
FFR Coupe #0635; Ford 347ci, Tremec TKO500, 8.8 rear end w/ 3.27:1 gears, Cobra/SVO brakes
