0
0
Driver door and dash
So I got the driver door rough fit, both of them closed and latch but rub doing it. I think im going to have to trim the hinge mounts to get the doors to move forward more. Also started working on the dash, got it almost done actually and got it mocked up into place, still need to run wires for the back up camera, the rear speakers and a couple other things. The next step will be to pull the seats out. I still haven't installed the under seat aluminum so ill get all that done at once. But Headed to Billings for the holiday, so ill be away from it for a while.
