philly15
ok, I wasn't sure if it was just simply a voltage reference back to the ecu that could be replicated. I planned on running my car s2000 style with a key and push button, but wasn't sure if there was a way around the immobilizer.
As Chad said, no way around it but it's pretty easy to basically ignore it like we did with his harness. As long as the box is working and can pick up the key frequency, it'll be happy so you can use any start method you like.
iWire
ok well I just wired the whole thing back in so should work, other than I cant find the antenna at the moment, but it should turn up. hopefully this all works out ok, Im now seeing why people pay to have this thing done. starting from scratch kind of sucks.
philly15
The immobilizer antenna is in the OEM steering setup around the ignition key switch...small white connector. {on the 06, don't know about other years}. I also looked for it for a while as the engine wouldn't start. Once connected..Bingo!
freds
thanks for that, I was wondering what the heck the single connector was I didn't have plugged in haha. On a side note, never again will I try to build my own harness. Im just praying it works right away, I don't want to have to trouble shoot this if it doesn't.
philly15
Good Luck!!!
fred
Brando
My iwire harness has worked flawlessly thus far. Just a shout out to Iwire for making such a great product. Thanks Brian
Thanks Brando! I appreciate you taking the chance on me. Plus driving your car has fueled the fire for me to get one.
C.Plavan
My IWire Harness looks awesome. I have not installed it yet, I just need to finish a few items before laying it inside.
Less typing, more working!
freds
Yep!
philly15
I totally understand, which is why I have a job.
