I was in St. Augustine a couple of months ago. A great city with a lot of history you can still physically see and enjoy.
Carlos
Carlos
FFR Coupe #0635; Ford 347ci, Tremec TKO500, 8.8 rear end w/ 3.27:1 gears, Cobra/SVO brakes
I was able to work on the Coupe the last 2 days some. I finished up the rear brake lines, installed the battery, main cut off switch and most of the wiring harness. I also installed the rear aluminum and made a custom center console part to hide the A/C some and house the A/C controls and radio stuff. Still lots of wiring mods to be done. I did get the engine to crank, spark to plugs, fuel pump running and rad fan run with both A/C and temp switch. I used Ron F dual relay setup for the fan. I had great luck with it on other cars I built. Also started to run some A/C vent hoses.
IMG_0720.JPGIMG_0721.JPGIMG_0722.JPGIMG_0723.JPGIMG_0724.JPGIMG_0725.JPGIMG_0726.JPGIMG_0727.JPG
I like the placement of the cutoff switch close to the battery. I mounted my battery up front so my switch was also up front in the passenger footbox side. You are a better man than I getting that trunk floor in in one piece. I had to cut mine longitudinally in order to get it in!!
Bill
Coupe #421, Picked Up 11/15/08, started 1/1/09 - Rebuilt mildly massaged 302, T5, 3 Link, and Loads of Extras
I have all the A/C, ignition and fan wiring working. I started to put in the Thermocoustic on the inside. I am going to get my dash cut in 2 so it will be easy to access wiring.
