Well in the above post you can see the before pics. Here is the after pics. new T-5 trans, 8.8 with 3.27 gears and Summit axles and all new bearings. I rebuilt the lower end of the 5.0 with ARP main studs, new main & rod bearing, new oil pump, Ford racing oil pan. I added Trick Flow heads, cam, lifters, push rods, Comp cams roller rockers, Professional Products Crosswind intake and Powerjection III fuel system. Also I used March's newest Sport track A/C and alt. system as well. I have 90% of the donor stuff ready for my type 65 build. I go to pick the kit up in Wareham on the 17th. I should be at FFR by the 23 or 24th after visiting family in the NE. This is my 3rd Kit. It is always nice to meet the folks at FFR. I wish I could have gone to the open house but that is not possible this year due to prior commitments.
