Before you install the pedal box, you drill a new hole for the brake push rod. Since it's closer to the pivot, this results in additional leverage at the pedal. You should be fine!
Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
I was also curious about using brembos without the booster. You could always go with an aftermarket replacement master cylinder of a smaller diameter if too much pedal force is needed, or a larger diameter if not enough fluid is being moved to clamp. Example:https://www.chasebays.com/product/su...ter-eliminator
I'm not sure of the accuracy, but I ran across this post which lists MC sizes http://legacygt.com/forums/showpost....99&postcount=5
