nuisance
The Boyd fuel tank seemed to be fuel starving at 1/3 full, adding fuel fixed it.
I am having the same issue. Kind of sketchy having sudden oversteer as your throttle cuts out cornering hard in 4th. I found that if I start a 20 min session with a 1/2 tank i'm going to have issues.
Sick build. I was curious about your front fender rub. Are you still limiting the shock travel with spacers? My fender rubbing went away with -3* camber.
Best of luck with your future track days.
