Brando
I am having the same issue. Kind of sketchy having sudden oversteer as your throttle cuts out cornering hard in 4th. I found that if I start a 20 min session with a 1/2 tank i'm going to have issues.
Sick build. I was curious about your front fender rub. Are you still limiting the shock travel with spacers? My fender rubbing went away with -3* camber.
Best of luck with your future track days.
Yes, I still have the blocks on the shock shafts. Even with 3* camber, when I took the springs off and swung the wheels, they hit the fender hard. Without the blocks, the only thing saving it is the stiff shocks, and the potential is there, as we saw in Factory Five's last race video.
