WEK, what Gordon does with his setup is what Mike referred to. You stagger the spacers to get the LCA's as close to parallel as possible. You simply can't do that using the FFR LCA's. You will also see better articulation with rod ends on the lowers. If I get out to the garage after work today I will get you a picture of the LCA's on mine.
