What is the easiest/best way to connect the FFR tank to 3/8" fuel line? From looking at the manual, it appears they use some adapter/quick-disconnect to adapt from the 5/16" feed hard line to 5/16" hose and another adapter to go from 1/4" return hard line to 5/16" hose. I'm looking at using 3/8" hose because I already have it and my FPR, fuel rails, and fuel filter all use 3/8.
I've had horrible thoughts that range from just clamping the 3/8 hose onto the 5/16 and 1/4 hard lines which I don't think would be too great. My other idea was to obey the manual and use the provided hardware from the tank, but then grab a couple 5/16 hose barb to 3/8 hose barb adapters and use that about a foot or so away from the tank to enlarge the hose size to the engine compartment.
Thoughts?
