Mustang Convert
I will be interested in the feedback on this one... I have the same problem with my Champs pan. Its a welded on nut and the sealing surface was not machined after welding. Heat from welding caused distortion in the sealing surface? Who knows... I have tried three types of gaskets (copper, rubber, nylon) and none of them fix the problem.
Agreed that at the price of these pans I was also left disappointed in the quality and attention to detail in their construction.
Kevin
MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
Delivered: 1/6/2012
First Start: 1/19/2014
First Go-Kart: 2/1/2014
Graduation: 1/4/2015
Graduation Thread
