Results 1 to 10 of 10
Thread: power coating cost
    Nepa
    power coating cost
    I know this is gonna vary greatly with what was done and who did it. But generally speaking what can be expected cost wise for the unfinished pieces and especially all the aluminum pieces. Thx. Sam
    Senior Member metros's Avatar
    NoVA
    I paid $400 for driver/passenger side interior aluminum, intake manifold, valve covers, coolant cross over, and A2W intercooler from VCP. That includes them doing all the prep work. I literally brought the valve covers with oil dripping off them.
    K3LAG's Avatar
    May 2013
    Greensburg, PA
    $225 for all the steel parts including door frames.
    Larry
    Senior Member AZPete's Avatar
    $200 for 19 aluminum panels, not door frames, but I sanded all to 220.
    Nepa
    Thx guys that helps
    Jan 2012
    Surry Va
    I can't do the aluminum parts but bought an oven for $19.50 at the Restore Habitat for humanity store. have done the brake calipers, control arms, and am working on the spindles and hubs, then the small stuff that F5 didn't do
    2bking's Avatar
    Garland, Texas
    What is the reason for not doing aluminum parts? I do all my aluminum parts with the Eastwood kit and a junk oven. Its easy and turns out professionally done but the parts have to be very clean and lint free per the instructions in the Powder Coating Manual. (See post #15 in my build thread) The time is about 45 minutes from bare to ready to install.
    King
    NoVA
    Oven probably isn't big enough
    Freeport, ME
    I extended the door to make it larger... take oven door off
    take out oven drawer, use it as inside of a new "door, made aluminum 2 inches bigger and it sits on blocks to seal off the oven and make it square. You could use two junk ovens facing each other with an aluminum "tunnel" inbetween and get much larger.
    I use eastwood's IR lamp to do bigger pieces, use IR thermometer and move the lamp to do larger parts. works great! I did my rear aluminum air vent grate just yesterday! I go to powders by the pound for add'l color choices. Different powders have diff temp and time REQ
    Dan
    Jan 2012
    Surry Va
    ovens not large enough for it
