Dave,Ok, I tried for several hours to bleed the clutch, with no success. I used a vacuum pump, but could not get any fluid to flow no matter how much vacuum pressure was applied. We later tried the vacuum pump attached directly to the master cylinder, and still could not get any fluid to flow. Shouldn't the fluid flow easily through the master cylinder if the clutch is fully out? Could there be a blockage in the master cylinder itself? Any ideas or suggestions would be helpful at this point.
As an aside, the clutch was smooth and worked well in the donor car. Can these things dry out or seize up if not used regularly?
Loosen up your clutch rod to add a little bit of free play to the pedal.
This allows fluid to enter the chamber.
