Thread: 06 WRX Limited donor in southern NH! Only 60k miles!
    Hollis, NH
    SOLD SOLD SOLD SOLD
    Hello 818 builders!
    I have a 2006 Limited WRX donor I would like to sell you for cheap. The car had 60k miles when it met it's end. It has a beautiful leather interior, aluminum control arms, red 4/2 pot calipers and many other parts you may need!
    The engine runs and has good compression AND leak-down!
    Front spindles with full brakes and front lower control arms
    • Rear spindles with brakes and e-brake handle/cables
    • Steering rack, tie rod ends, and upper steering column assembly
    Pedal box and throttle pedal
    • Master cylinder and brake booster, and clutch master cylinder
    • Engine with turbo and intercooler (if WRX model)
    • Exhaust manifolds, O2 sensors, and down tube
    Transmission
    • Rear lower control arms, toe links, and CV joints
    • Front seats, front seat belts, and gauge pod
    • Fuel pump
    Radiator
    • Wheels and tires
    • Door hinges, rear w/ latches,strikers, and inside door handles
    • Side view mirrors, left and right
    • Rear view mirror
    • Rear seat belts
    Parts in Red are not included or will not fit the 818. The only caveat is that this car has an automatic transmission. But don't let that stop you! You could sell the remaining parts and even make a profit on this donor! I'm only asking $4,000. I can deliver too!
    Ryan (a fellow FFR car owner)
    What would it take to mate a 5 speed to the engine? Would you need to tune the computer differently also?
    Hollis, NH
    I am not sure to be honest. I believe you would need a manual car's computer.
    oh man, can't believe I missed this.
