15
Had a bit of an issue marrying the Access port to the ECU, it took a few days to figure out with the help of John and Corbin at Fathouse Fabrication, the guys at Cobb Tuning and Brian at I wire. The culprit was my AIM Dash, good news is guys much sharper than I figured it out and found a simple work around, and happy to report everything works and got the car tuned. I am really please with how my stocker EJ205 (with a JDM Header and VF37 Turbo) runs.
I asked Corbin for 2 maps one for NASA and one to play with just because. The low boost map is 14lb 257.71hp, 227.80 torque, the high boost is 17lb 283.77 hp, 257.57 torque.
It was a productive day, now unfortunately I am tied up at work the next few weeks then taking my wife on vacation on the 12th so track time will be really limited.
