Results 1 to 14 of 14
Thread: Video of my 818 smoking the tires
    USA
    My brake bias is way towards the rear right now so it's difficult to stop the car and get a good burnout going.
    The car has no problem lighting off both of the 255 width 280 tread wear tires that I stole from my Saabaru. I still get wheelspin on dry pavement when I floor it in 2nd. I can't wait to have more power.
    Denver, CO
    Awesome. Thanks for sharing. I hope some more people can get some videos up. Any chance you could do a dash video showing a 0-60?
    Richmond, VA
    Nice video. The fit looks great on those wheels. What is the size/offset? Also, do you have any spacers?
    Do the rears rub at all?
    USA
    Thanks for the compliments. The car is so much fun to drive.
    The rear fitment is a little wacky at the moment. The wheels are 17x9 et42 and I think they would clear all of the suspension components, but currently I have 1.25" spacers installed and the tires stick out 3/4" from the fender. I plan to test fit them without spacers at some point. I'm running -1.5 degrees of camber, so there is some room for additional tuck if you ran more aggressive rear camber.
    The regular wheels I'm using are stock '06 WRX powder coated black, 17x7 +55. They were way too deep in the rear fenders and looked silly so I added the spacers.
    Member tango68ss's Avatar
    Mar 2014
    SMOKIN"!! Sounds killer!! Can't wait to see more!
    USA
    I'll try to get a dash cam at some point.
    Senior Member metros's Avatar
    NoVA
    Agreed^^^
    Sounds awesome. Details on exhaust set up? What size turbo? Headers?
    USA
    Agreed^^^
    http://thefactoryfiveforum.com/showt...-Exhaust-Setup
    Thanks! It's a TD04 with stock headers.
    NoVA
    For $80 you can't beat the sound coming out of that exhaust.
    Glad to see I found more videos that I hadn't seen yet.
    Encinitas, CA
    Need... Pshht... Moar... Pshht... Traction... Pshht...
    Denver, CO
    Awesome! Or just tape your phone to dash in front of speedometer. Nobody has any actual 0-60times. It would just be cool to see how fast an 818 is.
    Michigan
    Looks great. Just subscribed to your YouTube channel so I don't miss more of your videos. Would love to see some true tests like 0-60, 0-100-0, straight line braking tests, and even some donuts.
    The resonator or whatever you have on the exhaust really sounds bada$$. You should get attention when you drop the throttle!
    Good luck,
    WEK.
