Results 1 to 12 of 12
Thread: 2 piece dash panel question.
    I thought I read some where that some have made or bought a 2 piece dash panel. I can see how that would be much easier to work on wiring and gauges. Do you just shear the panel at the 90 degree bend or do you make or purchase a new 2 piece unit? Thanks.
    Senior Member STLMARSHALL's Avatar
    St Louis, MO
    Cut behind the cross support and rivet in a piece of aluminum. Drill the aluminum piece and install rivet nuts.
    Mike......FFR Coupe #340, 2003 LS1 350 RWHP, TKO 500, QT BH, Champ 10 QT pan, 5 Lug and AC, Cobra Disc, SAI mod, Nitto NT-01 275/315 ..Licensed for 28k..Just over 30k w/race tires and many mods
    http://s464.photobucket.com/albums/rr2/mmarshall01/
    http://www.youtube.com/user/stlmarshall
    2011, 2012, and 2013 St Louis region XP Champion
    Senior Member Rodster's Avatar
    Orange County, CA
    Cutting the dash
    I used my trusty Makita jig saw, and cut it at the bend. Not sure if this will work, since I am still building. Others have cut their dash - check Chris's site - awesome reference for the entire Coupe build. THANKS to Chris B. Also good are posts from Fluge.
    http://wayne-yoshida-kh6wz.com/2013/...attery-ectomy/
    and
    https://www.flickr.com/photos/51103049@N00/collections/
    and
    http://thefactoryfiveforum.com/showt...s-Build-Thread
    Ordered Type 65 Complete Kit Aug 29, 2012 - The 50-50 $ale!
    Standard Width IRS; Halibrands - 17x9, 17x10.5
    Kit Arrived: Oct 9, 2012; Build Started: Oct 28, 2012
    WordPress: http://wayne-yoshida-kh6wz.com/
    LinkedIn: www.linkedin.com/in/waynetyoshida
    YouTube: http://www.youtube.com/user/kh6wz?feature=results_main
    Thanks guys. Great ideas.
    Senior Member CJBergquist's Avatar
    Palo Alto, CA
    YES...do a two piece dash. I cut mine about 2" from the bend. I used a sheet metal roller tool to put a 3/4" flange on the 2" piece so the top would sit flush on the 2" piece. I don't have a good photo but if you look close at the finished dash you can see how it sits flush.
    [IMG]IMG_7118 by cbergquist1, on Flickr[/IMG]
    [IMG]IMG_0186 by cbergquist1, on Flickr[/IMG]
    If it's too LOUD....you're too OLD!!
    Build Site >> http://www.flickr.com/photos/51103049@N00/collections/
    FFR#0441CP Complete Coupe kit, IRS, T-5, 392ci 351W, Webers, Delivered 4/29/09
    Gorham, ME
    I did mine slightly different, cut about 1" from the bend so it sits on dash crosspiece and fastenen with rivnuts. Discarded the forward piece and nade a new one about 1/4" wider than the dash so it slightly overhangs the dash and then upholstered with 1/4" padding and Mercedes Benz vinyl material. Made 4 aluminum clips at the forward end to catch the fiberglass body and fastened the rear with 4 SS screws and finish washers across the top.
    Bill
    Coupe #421, Picked Up 11/15/08, started 1/1/09 - Rebuilt mildly massaged 302, T5, 3 Link, and Loads of Extras
    Gorham, ME
    Oh, and I finished the metal area where the gauges mount with wrinkle black powder coat.
    Bill
    Since I like to keep things simple I just cut the dash at the bend. I installed nutserts on the front and top of the square tube and screwed the two pieces to the tube with 8-32 button heads. The top piece has the bubble seal on the front and is plenty secure. The two piece dash was recommended by Russ Thompson early on and was easy and very helpful.
    IMG_0729.JPGIMG_0731.JPGIMG_0732.JPGI ended up cutting it 2" back and using a combination of rivets and riv-nuts. Thanks to all for their input.
    Quote Originally Posted by loeffler1 View Post
    Bill, I was thinking along the some lines with the top piece extending rearward past the front of the dash. You extended yours ¼” would extending it further to help shade the gauges be possible? If it can extend further how much further would be safe to go without running into issues of hitting your knuckles when making turns.
    Bill Lomenick
    Chotis Bill
    Gorham, ME
    Bill
    In answer to your question, the best I can do is direct you to FFR site. Click on News + Events tab, scroll to bottom, click on page 3 and scroll down to 8th item "Bill L graduates Type 65 Coupe #421". Scroll down to 4th picture and you'll see dash closeup. I added a shield, also powder coated wrinkle black, over the instruments tucking it just below the 1/4" lip which can be seen. As can be seen the upper dash piece is covered in Mercedes Benz leather like material. I also adjusted the steering wheel out just enough to keep knuckles from dragging. 5,000 miles later and no issues other than switching wood wheel to leather wrapped one. This wheel is larger in diameter and helps tremendously without power steering and gives a better grip. I also did away with the removeable steering wheel hub as I have trained myself to slide into the seat without having to remove the steering wheel. I did this mostly to remove the slop from these splines which was most disconcerting at 70 on the interstate with 1/2" steering wheel play from side to side. I hope this answers your question.
    Bill
    Thanks for the info.
    Bill Lomenick
    Chotis Bill
