Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 203
Thread: Chedda's 818S build thread
    Oct 2014
    Denver, CO
    Well, I gotta put the project on hold for a couple of days. I ended up getting sick. We had our first snow last night and I wasn't up for the challenge on working on the car. What I can do for you guys is provide a pic of the progress on the front end.
    http://i.imgur.com/J2jWhCb.jpg
    First, get well.
    Second, until the last few words, I thought you were to provide us a pic of the damn snow, but thankfully you posted a car pic.
    Third, which brings me to a question, I can't clearly see due to the angle, but were you able to screw all the threads in on the longer sleeves of the UCA?
    Oct 2014
    Denver, CO
    The UCA has not been tightened down yet. I wanted to get all pieces on first and then adjust. I havent gotten that far.
    Freeport, ME
    Quote Originally Posted by chedda View Post
    The right side triangle piece is mounted wrong, the holes are supposed to be on the vertical tube in front of the end of the tunnel, one hole for the shift cable the other big one for wiring
    While we're being picky. You are missing the aluminum block off plate behind the master cylinder.
    I would not fix the triangle. Drill a new hole for the shifter cable. Use the existing holes for wiring.
    Happy building
    Oct 2014
    Denver, CO
    the aluminum block off plate, I could not find in the kit. I looked in all the boxes and found none.
    everything else, what?
    Leesburg, VA
    It's in a small bag with some other aluminum parts. It should be with the rest of the sheet metal aluminum or the expanded metal mesh.
    Here is where the book says the hole go.
    Oct 2014
    Denver, CO
    oh snap! uhhh shwing... LOL
    The short sleeve of your UCA is toward the rear?
    Yes, yours are backwards. see below.
    Yeah that's an old picture. I switched back months ago.
    Then why did I ask the question?
    Oct 2014
    Denver, CO
    in the instructions, it showed that as followed for the UCA to have the shorter arm in back.
    That's correct and I must have known cuz I checked again yesterday for another reason. I guess I need some vacations...
    Oct 2014
    Denver, CO
    I got some sad news everyone... I was replacing the heads on the motor and while putting on the new heads, the headbolt snapped. So now I am in search for a new block. Unfortunately it is outside my scope on how to do. A couple of guys on the south denver subaru club page are helping me out. Hopefully I will have an update after the holidays.
    Yeah that's sad news. I know how you feel, I've been through a ton of such sad news cuz of one other person.
    Does it block you from moving on on other things on your build or you can still progress somewhere else?
    Mechie3's Avatar
    Why do you need a new block?
    Chedda
    please explain why this is a big deal.
    My first thought is to take the head off and use an easy out screw extractor then reassemble. There must be more to your decision to get a new block.
    Sorry to hear it Chedda. Were you re-using an old head bolt or something? Do you know why it broke?
    If you can't extract it yourself, I'm sure a machine shop could do it for you.
    Exeter R.I
    Why do you need a new block, you can get it out, or a macine shop will. You certainly don't need a new block man.
    Oct 2014
    Denver, CO
    The reason for the new block is because the steel head bolt (re-used) snapped in the threads while trying to tighten it down to spec (75lbs). I got to 35 lbs of torque and it snapped. The bolt goes into the block 3-4 inches before it starts to thread. I guess about 1.5 inches of thread is stuck inside the block. It is highly recommended by all shops and subaru to replace the block. Yes, a machine shop could drill it out and then use a larger bolt with thread but you would have to do it on every single one. Now it is out of spec and trying to find the right threads in the size could be dangerous. Instead of hassling with it, a new block it is.
    Leesburg, VA
    You can still extract the part of the bolt that broke off in the block without drilling the hole out and making it bigger. Just saying, you don't have to scrap your block. All you need to do is drill a small hole into the part of the bolt that is broken, and use a bolt extractor bit to pull out the thread. The thread is just sitting there and should spin out easily since there's no bolt pre-tension anymore. I've used this technique before multiple times. Since it's a deeper hole as you mention, I'd recommend securing the block on a drill press or mill for stability. Once the broken bolt is out, chase the threads and you're good to go.
    When drilling the small hole in bolts that is way down in there. I use a bushing around the drill bit to keep it centered. With this method a drill press really isn't necessary.
    Oct 2014
    Denver, CO
    The problem I need a drill bit long enough that is on the smaller side. Anything that is too long, it will snap.
    Mechie3's Avatar
    I drilled a 1/16" hole in a titanium piece with a 6" long drill bit the other day. I had to be careful, but it was doable and precise enough to press in a roll pin when I was done.
    If you want a new block it's a good excuse to get a new one. If you don't want one/budget won't take it you don't need a new one.
    Leesburg, VA
    I like the bushing idea but since a small drill bit needs to be used, the drill is still prone to tilting if held by hand, which can snap the bit. A drill press or mill will keep everything square.
    Correct, doing the repair is easier said than done but a drill bit is much cheaper than buying a new block. I'd at least give it a shot. Good luck either way
    The drill bit really isn't that small.
    For the M11 bolt the recommended drill bit is 1/4"
    I don't have a drill press or a mill that an engine block will fit in.
    About 2 years ago I had a starter snap off the bottom of my boat engine.
    (mercruiser small block chevy)
    We only had about 5" of clearance between the bottom of the boat and the engine block.
    Using an angle drill with bushing drilled the hole. Could not even see what we were doing.
    Tapped in eazyout and the bolt came right out.
    Question For Chedda.
    With the head off, how deep is the broken off bolt?
    Oct 2014
    Denver, CO
    I'll take pictures for you guys tonight and post them. I have avoided the garage since it happened.
    Edit:
    Pics of the bolt that snapped.
    http://imgur.com/a/ZJdVk
    Senior Member TahoeTim's Avatar
    Mar 2014
    Lake Tahoe
    back to the front UCA's.
    Do the grease zerks go up or down?
    Yours are up on one side and down on the other. I reassembled mine so they were up.
    Freeport, ME
    put them however you like, the effective position of the pivots does not change, up or down... the suspension is defined by a line through the center of the ball joint pivot and the center of the inner arm pivot. Mine are facing down
    Oct 2014
    Denver, CO
    Gaskets, ARP studs and the new motor will be here this week. Woot!
    Oct 2014
    Denver, CO
    Keith at SixStar has once again delivered! I'd like to thank him for a great price on the new motor and being pretty lax on the getting the old motor to him. I can't wait to start working on the new motor tonight
    Congrats!!! Glad to see things worked out.
    Oct 2014
    Denver, CO
    Quote Originally Posted by coloskydiver View Post
    Thanks!
    I have started working on the motor. YAY!!!! I have the heads on and that is about as far as I got last night. I had a buddy get a flat and he didn't know how to change a tire. I lol'd for a second and took his man card. Let me tell you, he knows how to change a tire now.
    updated pics
    http://imgur.com/a/kKJru
    Encinitas, CA
    Congrats... good luck with the build!
    Seriously? Who didn't learn that in drivers' ed? I would have told him to call AAA! The last buddy I had to rescue on the side of road really deserved all the **** we gave him. A bunch of friends were up at Mammoth Mountain; we had skied all day, partied that night. Around midnight one friend who was coming up late called to say he ran out of gas on the highway a few miles short of Mammoth. For those of you who don't know, if you're driving in the High Sierras in winter, you go prepared! chains, water, blankets, etc... (remember the Donner Party?) running out of gas is just so foolish. Well I hopped in the Audi and came to his rescue. His excuse? He filled up before leaving and always made it on one tank before!
    Oct 2014
    Denver, CO
    Thanks!
    another update for tonight. I started working on the motor and taking things off the old. I got to the water pump and by gholly, work called. Being on call sucks. Finished the work crap 3 hours later. I came back outside and finished lots of things.
    pics
    http://imgur.com/a/3WeIB
    Puyallup, WA
    Dont forget to install the back timing covers before putting on the pulleys.
    Oct 2014
    Denver, CO
    I don't have the covers. I'm not going to worry about the covers :P
    They are cheap from the dealer and if some road debris kicks up or falls down into there, you run the risk of bending valves due to timing belt interference, breakage, etc
    Oct 2014
    Denver, CO
    Well, I was able to almost finish up the motor over the weekend.
    Things that are left
    Oil pan install
    Oil cooler transfer (stuck hose on old block)
    2 coolant rubber hoses need to be replaced (knicked while taking the old block out)
    Cam gears for the passenger side (stuck gears - the threads or bolt is not stripped, just being a PETA)
    New engine mounts need to be purchased - the old ones got munched pretty good
    Pics!
    http://imgur.com/a/9TPRl
    Let me know if the headers would not work. It would be a bummer
