Ellimist
Ya, but seems like there was someone else, as well. At any rate, it looks like he dealt with it by centering the seat based on the steering column (i.e., closer to the center console):
http://thefactoryfiveforum.com/showt...l=1#post167544
Also,
this post shows that his steering column wasn't square with the frame, so he squared it up.
I also did it, pics somewhere in my build thread. Just bugged me too much, so I moved the seats together. Doesn't leave any room for a centre console though.
Adam _____ Instagram @PopesProjects____
YouTube Channel
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
So I'm having some issues fitting battery boxes behind the rear firewall plates.
Anyone see any issues with mounting the lower rear firewall plate to the cross beam adjacent to the seats? Basically on top of the cross beam where the seal rails rest? I figure some cutting and re-bending is in order. Weaken material? Going to be a fit up nightmare?
