0
0
Wiring pin removal
I don't believe there is a dedicated thread on this anywhere, so I figured I would start one for reference.
I was working on the wiring and realized I had "dieted" 2 wires that I shouldn't have. To make matters worse, they were both in connector B71, which plugs into the steering column, so there is no easy way to simply route a new wire around the connector. As a result, I had to figure out how to remove the pins from the plug.
The PDF at this site was helpful, as it highlights the secondary locking feature on many of the plugs. I will snap a few photos when I get home, but the bottom line is that the pins are fairly easy to remove with a very small flat head screwdriver. You simply need to remove the secondary locking feature first, then use the flat head screwdriver to release the locking tab and push the pin out.
http://techinfo.subaru.com/proxy/607...4760668812.pdf
In my case, I have removed the pins, and will replace them with short wires/pins from other dieted connectors that I didn't cut off way too short to begin with.
The flat head screwdrivers I used are similar to these: http://www.amazon.com/Precision-Slot...ad+screwdriver
For the 2002 to 2005 WRX ECU the pins that go into the ECU are Tyco Amp 316836-1. I got them from Mouser, 100 pack for $13.
- You may not post replies
- You may not edit your posts
Forum Rules
