So the Plan..... (im in Canada, so things cost a little more up here, sorry about the formatting, the forum kills my column alignment)
GTM
Expected Parts list. (based on exchange rate of $1.163 USD = $1 CAD)
Item USD CAD
Base Kit $22,999 USD $26,747.84 CAD
Donor Car $11,500.00 CAD (After shipping etc)
Transmission $9,500 USD $11,048.50 CAD
Rear Wing $1,350 USD $1,570.05 CAD
Wing Mounts $489 USD $568.71 CAD
Rims FFR $1,650 USD $1918.95 CAD
Tires Front $508 USD $590.81 CAD
Tires Rear $698 USD $811.78 CAD
Canadian GTM Kit $1,995.00 CAD
AirCond $1,350 USD $1,570.05 CAD
Cold Air Intake $399 USD $464.04 CAD
Splitter $499 USD $580.34 CAD
Rocker Extensions $499 USD $580.34 CAD
Roof Scoop $199 USD $231.44 CAD
Fender Louvers $199 USD $231.44 CAD
Telescoping Steering Adapter $156 USD $181.43 CAD
Adjustable Rod Ends $199 USD $231.44 CAD
Kit Shipping $900 USD $1046.70 CAD
Aluminum Gas Tanks $895 USD $1040.89 CAD
Side Scoops ????
Rear Louvers ????
Sway Bar $659 USD $766.42 CAD
Kooks Exhaust $2,083 USD $2,422.53 CAD
Coolant Tank $200 USD $232.60 CAD
Traction control $2,112.79 USD $2,457.18 CAD
5 point bracket $275 USD $319.83 CAD
5 Point Seatbelts $240 USD $279.12 CAD
Fuel Regulator $171 USD $198.88 CAD
Fuel Pump $369 USD $429.15 CAD
Fuel Filter $115 USD $133.75 CAD
Fog Light Brackets $37 USD $43.04 CAD
Porche CV Joints ?????
Total Cost $70,139.64 CAD $73,646.63 CAD W/TAX
All usa parts are being delivered to http://www.attheborderstorage.com I will then drive down to the US and pick the parts up with my flat deck. Saves me some $$$ on having crates made.
I was thinking this for rubber (I don't plan on driving this except in perfect weather)
Proxes R888
http://www.tirerack.com/tires/tires....R888&tab=Sizes
Transmission will be the Mendeola
Rear wing from here
http://vraptorspeedworks.com/apr-gtc...ber-rear-wing/
http://vraptorspeedworks.com/vrsw-ne...-mount-system/
gas tanks from here
http://www.fueltankparts.com/aluminu...ory-5-gtm.html
I need a pair of these (yet to find)
http://vraptorspeedworks.com/custom-...dy-vents-pair/
sway bar
http://thefactoryfiveforum.com/showt...able-for-order
exhaust
http://vraptorspeedworks.com/complet...xhaust-system/
Looks like an awesome plan for your build - congrats and good luck! You will find that the people on the forums will be behind you all the way and are great help. Amazing group of people here.
Get in touch with Shane at Vraptor early and often - most experienced builder and as you have already figured out he has created some great parts!!!
Have fun!
