Just an idea, but instead of all the lifting and positioning of the lift and then lifting to clear the wheel wells, etc. you could also just lift the car like Stewart did, through the windows on the upper cage members. Don't know if you can slide the lift rails in as you back the car/trailer into position or not, as getting them in the windows once the rig is in position may be a bit difficult. Just a thought.
