Results 1 to 13 of 13
Thread: MKIII Challenge car Sold!
Hybrid View
    Port Charlotte, FL
    Gorgeous dual purpose, street/track, race-ready, pampered, MKIII Challenge Car for sale. Impeccable, accident-free. 2,490 Miles. Seldom used, only for track days and a few single-day summer drives. This car was built by me and sold to my friend that no longer has time for her. I was focused on reliability when I built this car. No effort/money spared. Always lubed with true synthetics. Unequaled eye candy and a joy to drive.
    Engine:
    - 95 Mustang 5.0 L
    - AFR 185CC aluminum heads
    - CompCams XE270HR camshaft, roller
    - Crane aluminum dual roller rockers
    - FMS 24lbs/hr injectors
    - Cobra intake with K&N RU-3130 air filter
    - Larger mass air and throttle body
    - Complete MSD ignition system (6AL, distributor, coil and wires)
    - Levy oil pan with functional thermostatically controlled oil cooler
    - Remote K&N HP-3001 oil filter
    - All oil lines are Earl’s braided stainless steel
    - Accusump 3.0 quart pre-oiler with manual/auto switch and gauge
    - Fluid harmonic damper
    - Ron Francis wiring harness
    - Energy Suspension motor mounts
    - Chasis dyno: 277 Hp, 300 ft-lb, corrected: 308-325 Hp, 333-352 lb-ft
    - Super-flat torque 2500-5500 rpm
    Steering/Suspension/Brakes/Transmission:
    - FMS power steering
    - Power steering fluid cooler and filter
    - Heidts power steering pressure adjust valve
    - Whitby power brake booster
    - 95 Cobra calipers and disks
    - Rear brakes pressure adjust valve
    - Tremec T-5 transmission with mid-shifter
    - FFR tubular front A-arms
    - 3 link rear suspension with 3.55:1 rear end gears
    - Safe Launch aluminum differential cover
    - Front adjustable Breeze NASCAR style sway bar
    - Vintage Performance fully adjustable rear sway bar
    - Koni coilover shocks
    Dry/Track Tires and Wheels:
    - Kumho Ecsta V710, half life.
    - Front, 275/40-R17
    - Rear, 335/35-R17
    Wheels:
    - CCW (Complete Custom Wheels), Classic, 3-piece
    - www.ccwheel.com
    - Front, 17x9.0, work order 15039
    - Rear, 17x12.5, work order 7859
    Wet/Street Tires and Wheels:
    - Pilot Super Sport, like new, 300 miles
    - Front, 245/40-17
    - Rear, 285/35-18
    Wheels
    - American Racing TorqThrust
    - Front, 17x9"
    - Rear, 18x10"
    Body/Other:
    - Full Safecraft fire suppression system (fuel tank, cockpit and engine nozzles)
    - Portable fire extinguisher in cockpit
    - Fuel Safe fuel cell – Bladder, foam and filter replaced in March 2014
    - Easily removable full windshield and 2 spec racer windshields
    - Driver and passenger Kirkey racing seats
    - 5-point Crow safety harnesses with arm restraints (2012)
    - Removable splined steering wheel
    - Front fiberglass splitter by Tony Chiles
    - Front nose splitter by Dark Water Customs
    - Autometer shift light
    - Angled Autometer gauges
    - FFR wipers
    - Trunk mounted hidden battery
    - Rear fender flares bonded in
    - Metallic candy blue paint job
    Spares or extra material, included:
    - Extra deep, extra low-profile 2-ton jack
    - FFR MK-IV front spindle kit
    - Set of Hawk HP-Plus brake pads
    - Eibach 0.25 Inch wheel spacer kit
    - ProWheel 0.75 Inch wheel spacer kit
    - FFR 4 to 1 header gasket kit
    - Breeze solid rack mount kit
    - Fuel cell foam kit
    - Driver’s seat helmet restraint
    - Convex center and side rear view mirrors
    - Second Autometer warning light
    - Water temp warning switch
    - Oil pressure warning switch
    - Koni coilover adjustment tool
    - Hotlap timing system
    - FFR Challenge Car build manual
    Registered and insured in MN. Now located in South Jersey.
    Pictures to follow.
    Sold!
    Henry
    Port Charlotte, FL
    Sold!
    Thx,
    Henry
    Port Charlotte, FL
    Sold!
    Henry
    Sent you a private message. Feel free to email me, or have your friend email me.
    Port Charlotte, FL
    PM replied to.
    Henry
    My message box is empty, maybe I'm new, and it's a feature I need to wait for?
    Anyway, can you email me? carphoria -at- gmail
    Port Charlotte, FL
    CP,
    Sorry, I thought I replied but could not find it. I just sent the response.
    Henry
    Member smokinss's Avatar
    Oct 2014
    Albuquerque, NM
    Sounds like a great deal. Is it just me or is photobucket not responding?
    Non Donor FFR#7399 MK4, Ford Cobra SVT 4.6L DOHC, Borg-Warner T45 5-speed, 3-Link, Cobra brakes, Halibrand replica 15" wheels, vintage racing seats, vintage Autometer Cobra gauges, painted ‘69 Corvette Tuxedo Black by Corvette Restorations, Firestone Indy 500 Firehawk Tires –235/60 R15 Front and 295/50 R15 Rear
    Port Charlotte, FL
    Sold!
    Thx,
    Henry
    Oct 2014
    Albuquerque, NM
    Thanks Henry that did it. Nice racer!
    Sent you two more PMs.
    Port Charlotte, FL
    CP,
    Just replied.
    Henry
    Port Charlotte, FL
    Sold.
    Congratulations Jon,
    Henry
