I picked up and 04 STI center diff that was burned out from a local shop in hopes of reselling my 06 center diff and came across the same issue that you have now. I went ahead and used the 06 diff since that was the easier way out.
In addition to bolting the adapter in, I also welded it around the entire perimeter of the flange after V grooving it.
It sounds like youre on the right path just make sure that center smaller shaft is long enough to have sufficient engagement into the adapter.
Kurk, how is that retained on the driven shaft? As I illustrated in the video, I think I'll have to retain the center diff housing to keep everything in place. Is the 06 center diff assembly just a lot shorter? Also, what is that additional flange behind the one you welded? Doesn't look like the FFR adapter, unless it's hidden in there.
