0
0
Fuel hose connectors won't fit
Hi Guys,
Probably a dumb question, but I'm having trouble getting the FF white fuel connectors to hook up to my 03 WRX engine. The FF fittings on the other end seem to connect fine to the tank, almost too easy, but then again double O'ring so shouldn't take too much press on force. Anyone else had the same problem. I hate to lean on them too much and break something. If the size is wrong, any suggestions where I might pick up a couple of these?
- You may not post replies
- You may not edit your posts
Forum Rules
